10-02-2008, 10:23 AM | #1 |
help with these bolts
how do you install these bolts that hold the upper control arms that adjust camber. I thought I could just hammer them in but they don't want to go. Thought I had better stop and get some advice before I tore something up.
10-02-2008, 10:33 AM | #2 |
It's a catastrophic success.
Re: help with these bolts
If you dont have room to drive them in with a hammer you can use a spacer(washers, piece of pipe,large nuts)and as you tighten them down it will suck them into the frame hole.
10-02-2008, 11:31 AM | #3 |
Looks good at 20-ft .....
Might try putting the bolts in the freezer for a while before you try to pull them into place.
Cold causes "shrinkage," as per a famous Seinfeld episode. |
10-02-2008, 11:38 AM | #4 |
get a bigger hammer
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations) Perry, Ok. We're just two guys, trying our best. 72 cheyenne super https://67-72chevytrucks.com/vboard/...d.php?t=811512 55 chevy truck http://67-72chevytrucks.com/vboard/s...d.php?t=840174 |
10-02-2008, 02:53 PM | #5 |
10-02-2008, 03:56 PM | #6 |
Freeze the bolt and heat the hole with a propane torch, then smack them in with a BFH, if you use the nut to pull it through you can damage the threads, and or stretch the bolt, neither of which is good.
10-02-2008, 08:49 PM | #7 |
thanks for the info, I did get 2 of them in with a ball joint clamp that I used to press them in with. That worked good until the clamp bent. Back to harbor freight to exchange it on friday and try to get the other 2 in.
10-03-2008, 12:12 AM | #9 |
Hollister Road Co.
They should press in fairly easy. Yours look like wheel studs not caster bolts. The stock bolt looks like below.
10-03-2008, 07:01 AM | #10 |
thats what i was thinking
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
10-03-2008, 01:17 PM | #11 |
Hollister Road Co.
I'd be afraid the small head on that silverstud may pull through after a while
10-03-2008, 06:22 PM | #12 |
I ordered these from LMC and this is what they sent me. I knew they looked different but so has everything else I've gotten from them. Where can you get the bolts that are original looking?
10-03-2008, 06:28 PM | #13 |
From a donor truck!? Maybe GM since those bolts were pretty common on just about every car or truck GM built?
10-03-2008, 07:42 PM | #14 |
Hollister Road Co.
10-03-2008, 08:56 PM | #15 |
sharp as a marble
I am with sneakysnake. If you set them in place and stack washers on them and then the nut, you can pull them into place. We do this alot to pull a lug stud into an axle at my shop.
10-03-2008, 09:28 PM | #16 | |
Chasin' the Dream
I find this to be very sound advice.
You can use both methods if you use one to assist the other. Snug up a nut on some washers and smack the head with the hammer. I would be careful not to use more torque than is specified for this application. This way you put less stress on the threads and decrease the chances of 'mushrooming' the other end with your hammer. I would also compare the striations carefully to make sure they are the same as the old bolt.
Born with a Bowtie 1971 C/10 350/350 Daily Driver/project Assumption=The mother of all -ups |
10-06-2008, 10:16 AM | #17 |
Don't waste your time with Harbor Frieght. Everthing they carry is total pile of Chinese knock off piece of #^@%%$#. Most things won't even survive one use let alone multiple uses. Do yourself a favor and buy decent tools that will last or borrow what you only need once. Check some autoparts stores that offer free loaner tools too.
1972 Cheyenne C10 LWB 1970 C10 292 I6 3 speed 2017 Silverado LS 4x4 1978 El Camino SS, LT1 swap 2016 Camaro SS |
10-06-2008, 02:34 PM | #18 |
To shrink them, go get some dry ice and let them chill on that. -109 deg F versus about 0 for your freezer. Just be sure to wear gloves when handling them..
10-06-2008, 02:44 PM | #19 |
Hollister Road Co.
If you have the correct bolts,, shrinking, freezing, BFHing and pressing doesn't have to be done. The washer trick is all thats needed to draw them through.
He has wheel stud bolts with a coarse spline trying to go int a fine spline. Thats why he's having issues |
