10-03-2008, 12:27 PM | #1 |
Always on the hunt...
Am/Fm comparison pics for Leddzepp
Scott, here are the pictures showing the rear case differences on factory truck - Van Am/Fm's, were the rear support strap would be attached.
10-13-2008, 07:00 PM | #2 |
Re: Am/Fm comparison pics for Leddzepp
Scott, the first two speakers are done. They have new voice coils, new speaker cones, new spiders and remagnetized magnets. First two shots are before re-build and the last two are after, final output/sound is great.
10-13-2008, 08:14 PM | #3 |
Moderator
They look great Mel! I only need one though for a factory radio, correct?
10-14-2008, 07:29 PM | #4 |
I would take the second speaker if they both will fit a truck it may be the angle but one looks bigger than the other to me.
~Chris "If your not doing anything then do it quickly!" Last edited by ctucker; 10-14-2008 at 07:35 PM. |
10-14-2008, 09:43 PM | #5 |
If, per se, he only wanted one, how much would you ask for the other?
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
10-15-2008, 02:36 AM | #6 |
They are both the same size 4"x10" / 10-ohm factory dash speakers. I am getting low on these OEM core's with the original/factory radio plugs still intact. Do you have an original non-working re-builder as pictured above for core/exchange towards a rebuilt one? Cost would be $30. for the parts and $35. for labor, also if you want your "Same" original speaker back it's not a problem, just a tad bit longer turn around time.
10-15-2008, 02:38 AM | #7 |
10-15-2008, 11:09 AM | #8 |
I do have the original speaker however it has the wires just not the plug. The original is a little ruff. I will have to do some checking because I may have another speaker laying around. I also have 3 am radios 2 working and 1 non, 2 are out of a truck and 1 van. if you rebuild that type of stuff maybe we can work out a deal. As far as getting the same one back that dosent matter.
~Chris "If your not doing anything then do it quickly!" Last edited by ctucker; 10-15-2008 at 11:10 AM. |
10-15-2008, 04:22 PM | #9 |
I looked i do have two here are the pics. Like I said there a little ruff let me know thanks
~Chris "If your not doing anything then do it quickly!" Last edited by ctucker; 10-15-2008 at 04:23 PM. |
10-18-2008, 08:11 PM | #10 |
Do you want that top one rebuilt/reconed since it still has the factory radio plug on it? Does the actual speaker basket/frame look good with no bends or signs of ever being crushed? Cost info is listed in the above post, Lmk.
10-18-2008, 08:25 PM | #11 |
10-19-2008, 09:49 AM | #12 |
I replied to your PM. I don't have anything...that stuff is always already gone from every junkyard rig I find.
