![]() Join Date: Mar 2006
van tilt question?
Hey guys, I have a van tilt from a 78 chevy van and my question is that the tilt has a button on the end of the turn signal lever. Will this titl work in a 68 chevy pickup? thanks Rick
Re: van tilt question?
It will work. You just need to shorten the shaft between the steering box and the column a little and buy the adapter harness so it will plug into your truck. The button is for cruise control. If you don't need cruise control you can just change the turn signal lever to a regular one. There should be a a single wire coming out of the column that goes to the lever with the button. All you have to do is don't hook it up. Hope this helps.
its all about the +6 inches
actually, it's a tripple wire with a single plug.
Firefighter
Yes it will work fine, the button is just for cruise control!!! Just need the adapter for the plug under the dash!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
