I've got a 69 non-air cab. I was trying to put an AC inner box in my cab tonight. None of the holes lined up for the studs that are attached to the AC box. I thought I had heard someone say that you could switch a heater only box for an AC box without any cutting, i guess I was wrong. How did you guys line up the inner box and decide where to drill the new mounting holes?
------------------ '69 CST Short fleetside Lowered, 400 small block, 700R4, 3" dual exhaust, 40 series Flowmasters, 4 wheel disc brakes, all stainless hard and flex lines, front & rear sway bars, Dana 9 1/4" rear end 4.11's w/Detroit Locker, soon to have 18" rims Not my daily driver. More like my weekend A$$ KICKER. See my truck at: http://www.geocities.com/low69cst/ Future Automotive Engineer attending the University of Kentucky. Feel free to message me on AOL, SN- SS95ZQ8 My Dad's projects: 72 Short Fleet 4x4 Chyenne Super 72 Long Fleet 4x4 Chyenne Super Both 350 autos restored original
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Old member
NO YOU CAN'T. YOUR RIGHT. If you have the out side ac box make a templete and mark fire wall, then inside will fit right up. Also you will need to cut the openings a little different. I added the factory ac to my 71 and had a templete and let a so called friend borrow it, guess what haven't seen it in about 4yrs. Once you get the temp. made lay it up on the fire wall and try and center up the temp. to the openings already there. That will give you the best starting piont I would think. It's been a while since I did mine and my father-in-laws. Hope this helps.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels, Pioneer reciever,100 watt amp, 6 disc changer, 2-10" subs (behind seat) 2-6x9 in doors, 2-3ways mounted under seat, and 2 tweaters on door panels www.geocities.com/chevy71tpi/main.html www.picturetrail.com/Andy4639
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
