Old 10-03-2008, 11:09 PM   #1
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
72 throttle cable shortening
I need to shorten my throttle cable about 3-4". Anyone elsedone this? If so, How?
TIA, Tom
Tom Vogel is offline   Reply With Quote
Old 10-04-2008, 01:09 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: 72 throttle cable shortening
bump...
Old 10-04-2008, 10:04 AM   #3
JimKshortstep4x4
I have not shortened any cables but is there any reason you can't use a shorter cable (like one from a 4x4)?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-04-2008, 10:37 AM   #4
Sinister
Between Trucks...
Sinister's Avatar
X2 on the shorter cable. But you could cut the gas pedal end of the cable, then cut the cable housing to length and use a couple of cable stops. I'd use a dremel or something similar for the cutting.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
