Aiming Headlights
Can someone refer me to some kind of chart as to how I can aim my headlights. I have just installed them and got them in the grill "eye ball close".
The truck is a K-20 ( if that matters) and I just need a guideline to go by. example :::::::::: 10 feet from wall low beam up so many inches low beam straight or off to the right? same info for Hi Beam or any other backyard methods you guys might have. Thanks a bunch once again! ![]()
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: ![]() |
Re: Aiming Headlights
I DIDN'T KNOW ANYONE REALLY DID THIS ANYMORE
![]() MIKE |
Parts and more parts
I agree with mgbmike OR you could take another vehicle and part it about 25 feet away from the garage door and put some masking tape on the spots that the lights center. Now you can take your truck to that same spot and adjust to match the light pattern. There are plastic tools on the market (made by Hopkins manufacturing in Emporia, Kansas) that you can use to adjust headlights. They sit up against the nubs on the bulbs and have levels in them for adjustment measurements.
I prefer the idea of sitting on a back road and the adjustment until I have illumination of the driving lanes. Now drive and adjust from there. |
My book says the low beams should be down and to the right of centerline 0 to 4 in. at 25 ft.
69 Chevy 4x4 383 Power ![]() |
#5 | |
so if I understand correctly, at 25 feet my headlights on low would be at the same center height at the garage door as on the truck from the ground up to headlight center and up to 4 inches lower and to the right???
Active Member
![]() Join Date: Jul 2007
Just did mine earlier part of the year. I got them halfway adjusted on the garage door/driveway and as mbgmike mentioned took it out at night on a dark road.
Don't take it out on a dirt or gravel road and try to find a concrete or lighter colored asphalt road. A dark asphalt road does not reflect very well and is hard to adjust the lights on it. Took me 3 or 4 tries to get it close. Also, don't forget to take a small flashlight with you so you can see the adjusting screws. |
looks like everything I googled said about the same thing.
pull up to a wall or garage door on flat driveway( mine isn't, darn!) and mark a spot with masking tape to represent the center of vehicle by sighting through back of window and down the center of the hood line. A yard stick straight out the centerline of the hood will do also. Then as close as you can get to the wall, turn on the low beams and mark the center of the light "hot spot" they call it. this is your reference. Now back up 25 feet and aim the lights down about 3 or 4 inches and centered to the original spots and centered to the center of vehicle mark. Be very carefull when backing up the 25 feet in your driveway however that you don't end up "T-Boning" a passing by car since most driveways won't allow you to back up 25 feet with out being out in the middle of the street. But I guess depending on what time of night, you might get away with the truck in the middle of the street. It might pay to have a spotter, while you are adjusting the aim, watch for traffic however since we don't want to get "T-Boned" ourselves!!!!!!! ![]() ![]()
