Old 10-04-2008, 05:13 PM   #1
drewfever1020
help me cuz im getti angry!
iv been trying to take this damn thing off for a while and i cant get it off!
im getting angry already!
i need to take it off cuz its in the way and i need to use my jack to raise my motor just a little to get my damn oil pan out!
here are some pics of what im trying to get off!
im trying to get that middle bar off!
how do i get these damn weird srew off?
can someone help me asap!
drewfever1020 is offline   Reply With Quote
Old 10-04-2008, 05:21 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: help me cuz im getti angry!
it's a rivet, so you will have to either
1. grind the head off then with a center punch and drive them out
2. or air chisel the head off
3. or drill them out with a decent drill bit.
they aren't exactly the easiest fastener to take out, but it's do-able with a bit of elbow grease. don't freak!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 10-04-2008, 05:32 PM   #3
BIG ORANGE
BIG ORANGE's Avatar
why is your pulleys so low in your truck? that doesnt look correct! your engine doesnt look placed properly! did you just get this truck??
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 10-04-2008, 07:14 PM   #4
drewfever1020
iv had these truck for about 9 months already!
im barly starting to do work on it!
Old 10-04-2008, 07:15 PM   #5
screamin_eagle
screamin_eagle's Avatar
I don't think you want to be taking that out. besides the oil pan should come right out.
screamin_eagle is offline   Reply With Quote
Old 10-04-2008, 07:46 PM   #6
BIG ORANGE
BIG ORANGE's Avatar
I agree with scremming eagle, that engine looks low in the cradle, but you dont want to remove that cross bracket! let us know if we can be of any further help.
Old 10-04-2008, 07:54 PM   #7
68gmsee
Active Member
68gmsee's Avatar
As tcb-1 mentioned, it's a rivet. I used an air chisel to remove them on a transmission crossmember. Could possibly be do-able with a hammer and a good quality chisel but you'll be madder'n a wet hen doing it that way.
For sure, one thing these old trucks will test is your patience and perseverence.
68gmsee is offline   Reply With Quote
Old 10-04-2008, 08:11 PM   #8
67dragtruck
67dragtruck's Avatar
I wouldn't take it out. Get a hoist from somebody to lift on the motor if you can't get it out any other way. Also try rotating the crank some if the pan is hanging on a particular spot on it to get it out of the way.
Tom
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 10-04-2008, 09:37 PM   #9
suville
suville's Avatar
If youre gunna use cinder blocks for jack stands turn it on its open side so the center web and sides support the wieght , I would recomend you make certain the brick is not cracked ANY where discard it If that truck falls on you you prolly wont need to be concerned about an oil pan!
suville is offline   Reply With Quote
Old 10-04-2008, 10:15 PM   #10
67chevyguy
67chevyguy's Avatar
first rule my dad taught me before I started working on my truck was don't ever put it up on cinder blocks. They will crumble without warning.
Jack stands are cheap, your body or life, not so much.
67chevyguy is offline   Reply With Quote
Old 10-04-2008, 10:31 PM   #11
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Calm down, I know you are angry but we cant help with you "screaming".
First thing is first, get jack stands, your life or a hundred bucks for safety.
Second, you dont want that cross member out. It is there to keep the front clip together.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 10-04-2008, 10:47 PM   #12
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
Also check the motor mounts, they may need replacing, from the looks of the motor in the cradle.
TennesseeZ is offline   Reply With Quote
Old 10-04-2008, 10:48 PM   #13
68C15
blood type; Retumbo
68C15's Avatar
I hope you werent planning to jack the engine up by the balancer. it will damage it and BAD things will happen. get an engine hoist and attach it to the front of both cylinder heads.
why you taking the pan off? leaking gasket?
68C15 is offline   Reply With Quote
Old 10-04-2008, 11:54 PM   #14
drewdude92
72 chevys 4 life
drewdude92's Avatar
to get the oil pan off is you gotta lift your motor up about 3 inches it is the biggest pain in the butt though...make sure you get that gasket sealed up because that would suck!!
drewdude92 is offline   Reply With Quote
Old 10-05-2008, 12:11 AM   #15
drewfever1020
ya man im gonna try to do this rite the first time cuz man that gasket is killing me!
thanks everyone for posting, i will take ur advice!
Old 10-05-2008, 12:26 AM   #16
C20_Paul
C20_Paul's Avatar
I had that same problem when I replaced my oil pan gasket. All you have to do is lift the engine up a few inches. You can pick it up by the harmonic balancer using a 2x4 and your floor jack. Just make sure that you have it steady before you go sticking your hands under the engine.
Just go slow and a have a buddy around to help out.
BTW I would recommend getting a one piece oil pan gasket they are WAY better than that four piece set-up that most places give you.
C20_Paul is offline   Reply With Quote
Old 10-05-2008, 12:33 AM   #17
c10chevy69
c10chevy69's Avatar
Anybody notice the bend in the driver side spring? There is one on pass side but not as bad.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug
c10chevy69 is offline   Reply With Quote
Old 10-05-2008, 12:41 AM   #18
Cyclone44
Step Brother
Cyclone44's Avatar
Yeah just do it the right way like all have said and be safe about it......
Cyclone44 is offline   Reply With Quote
Old 10-05-2008, 06:42 AM   #19
68C15
blood type; Retumbo
68C15's Avatar
that is from a "blue flame" suspension drop. that thing has to ride like a freight train now.
Old 10-05-2008, 07:40 AM   #20
70GMCer
70GMCer's Avatar
Just do this!! It's easy!! http://67-72chevytrucks.com/vboard/s...91#post1487791
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-05-2008, 09:06 AM   #21
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Originally Posted by 70GMCer View Post
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
