Old 10-04-2008, 05:20 PM   #1
skillet
skillet's Avatar
Smile FYI Code 44 on '89 suburban
Had a code 44 set last week, so I stopped and picked up an oxygen sensor, assuming it might be the sensor. But I had just replaced the sensor a few yrs. ago. Anyway, I was unplugging the sensor to change it out when I felt a little roughness on the wire upstream of the sensor wire connector. When I got a light to check it, sure enough about 1/2" of the insulation was gone on the wire. I theorized the missing insulation was allowing the wire to heat up and cause the resistance to change and consequently vary the voltage. So I taped up the wire where the insulation was missing and it solved the problem, no more MIL coming on. Like they say always check the simple stuff first. I will better repair the wire, now that I know that's what it was. Maybe this will help someone else sometime.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter
skillet is offline   Reply With Quote
Old 11-16-2008, 12:46 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: FYI Code 44 on '89 suburban
Good info. Thanks for sharing...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
