![]() Join Date: Oct 2006
Ford front axle?????
I have tried this question elsewhere without real luck.
Has anyone here ever put a 1/2t Ford front axle,radius arms/track bar in a chevy? I think it would be VERY easy. Bolt on the front spring bucket,radius arm brackets,make a track arm bracket and put it in. The only draw back is the transfer case. I am looking for a SMOOTH ride. I just want this thing for toolin around in with my boys(fishing,small game hunting,camping). Thanks in advance. -Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT Last edited by manimal; 10-04-2008 at 11:40 PM. |
In House Collision Technician
Re: Ford front axle?????
hey there. i would say it could be done easy enough as long as the width of the frames are close to the same at the spring buckets & track arm brackets. it would be much easier if u're truck is currently a 2wd. that way, u could use a divorced 205 case from a ford as well. then u have to consider all the little things like 5 lug front with 6 lug rear. it's easy enough to have the axles re-drilled but it all takes money. as far as my memory serves me from my mud bogging days, the fords did ride a little smoother but they bounced down the road as if u were on a pogo stick. i would consider a chevy front with a 4 in. soft ride spring. they ride great & as long as u don't punish them off road, they hold their arch fairly well.
what truck? the pre 1980 Fords have spring spacing very close to chevy. I have seen a few Chevy's over on Pirate that have Ford Hi-pinion dana 60 front axles out of 78-79 fords.
for transfer case, you could either go with a divorced ford case (they also used a dana divorced case, and some even had divorced NP203's if you maybe forsee a doubler in your future) or get a later model chevy transmission with the round pattern...the Ford round pattern is very close, but I believe if you make one of the holes oblong it will bolt up. then you can use any Ford round pattern t-case, provided you have an adapter that will work, and the proper input gear.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 10-06-2008 at 12:34 AM. |
#4 | |
Seems like less work to invest in some better spring packs and high end/good quality shocks IMO. Alcan will set you up with whatever style suspension your looking to create and a set of Bilstein's can handle it from there. Always interested in seeing a new twist though, give it a shot and let us know how it works out. |
Sorry, I was talking about converting a 2WD 75 C10 to 4x4. I dont think I made that clear.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
it would probably be in u're best interest to buy a complete 1/2 ford 4x4 for the conversion. u'd get all the brackets plus axles but u would still need the divorced case. u might as well just use the whole ford as u're driver & save u'reself the aggravation & time. of course, then u have to deal with the humility & embarassment which to me, would be worse. lol
#7 | |
I saw one in a magazine years ago. if i remember right, he welded Ford arm mounts to a Chevy front axle. The truck had a coil sprung rear, and looked very nice.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
huh ???
The Ford front has a drivers side drop where the chevy has a pass side drop...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" Last edited by 72 CustomCamper; 10-10-2008 at 05:58 PM. |
I'm a poor spectator
Cool people drive Fords
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
huh ???
73-79 was my favorite ford truck body style...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
#13 |
Me too!
#14 |
here are some pics of a Chevy van I took with a ford front end. sorry i dont have pics of the uper spring cups. Its not the cleanest job in the world but it will kind of show you what they did. they did use a divorced ford NP205 to.
Earl 68 2500 4x4 GMC Burb |
#15 |
OMG, that is scary!!! And it's a Dodge van. I would get a truck that is all together, this way you have all the pieces that you need. Measure, then measure again, then after you measure, measure again so you only have to do it once. I was gonna do this to be different and have a nice ride, but got lazy and put leaves on....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
#16 |
the man who built that needs to be tied to a tree & beat with a dried-up rose bush branch until he passes out from shock!!! that is deadly in soooo many ways. i especially like the s shaped drag link & upside down shocks.
#17 |
Its not as bad as it looks I think if he would have not used the multiple shocks and centered the transfer case more it would have been a decent ride. I’ve seen swamp buggies in Fla. that made this thing look like an engineering master piece. They did do a good job at making the brackets and the welding looked good. The s drag link is no big deal there are brand name lift kits for jeeps that come that way. I think if it wasn’t so high in the air and the brackets were closer to the frame it wouldn’t look so crazy. The only thing that is totally goofy is putting that transfer case to the rear like that and having almost no rear drive shaft it’s like they spent all this time fabbing the front and then just threw the rest together. I stopped and looked at to see if it was worth buying for the rims and tires. It wasn’t.
