Old 10-05-2008, 10:34 AM   #1
msgross
msgross's Avatar
manual tranny staying in gear????
Why would my 4 speed tranny be "stuck" in gear? Right now it's in the rolling chassis but when I fire up the engine it turns the transfer case no matter if the shifter is in neutral or not. When I had it out did it somehow get "stuck" in gear? The shifter moves fine like it should it...
any ideas?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-05-2008, 11:02 AM   #2
Old Chevy Mech
Keepin it runnin!
Old Chevy Mech's Avatar
Re: manual tranny staying in gear????
Could it just be the gear oil dragging the gears and not actually in gear? When the engine is off if you try to turn the output shafts will they move or are they definately engaged to the engine?
Frank
1970 K-5 4X4 Blazer
1970 K-20 4X4 Long Bed
"Liberty Means Responsibility, that is why most men dread it"
Old Chevy Mech is offline   Reply With Quote
Old 10-05-2008, 12:07 PM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
are your drive shafts attached? it not then usually it will spin due to the thickness of the gear oil in the transfer case..
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-05-2008, 12:26 PM   #4
msgross
msgross's Avatar
no driveshafts attached, i'll try to spin the tranny with it the engine off.
The TC shouldn't move at all if the tranny is in neutral, but it does...
If I put the TC in neutral then the yokes stop...
The Garage:
Old 10-05-2008, 12:51 PM   #5
Firefighter
It will spin the yokes though if there are no shafts hooked up, kinda wierd I know but it does. It's kinda like a Backhoe if you have ever watched one while it's digging, the rear wheel will spin when it is lifted up on the stabilizers even though it is in neutral. If you hook up your shafts I promise you it will stop spinning!!!!
Yellville, Ar. USA
Old 10-05-2008, 12:57 PM   #6
msgross
msgross's Avatar
if it doesn't then my neighbors will see a heck of a sight as I run down the road after it!
The Garage:
Old 10-05-2008, 01:00 PM   #7
Firefighter
Talking Re: manual tranny staying in gear????
LOL!!!!!
Yellville, Ar. USA
Old 10-05-2008, 01:09 PM   #8
msgross
msgross's Avatar
maybe I could hook up a lanyard like a snowmobile, I fall off and it dies!
The Garage:
