10-05-2008, 11:10 AM | #1 |
'73-'74 Grille in a '76?
I would like to replace the grill in my '76 with one from a '73-'74. I thought I had read somewhere that it would fit, just need the right clips. Is that all that is needed or is there something else? By doing this, will I need to modify anything else? Like changing my hood release for some reason? I have the under hood release, not the cab cable pull type. Thanks for the help, DOOCE
1976 Chevy 1/2T 2wd SWB 327/Saginaw 4spd 3.73:1 LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071 LFSalleeII@gmail.com |
10-05-2008, 11:41 AM | #2 |
Georgia Boy
Re: '73-'74 Grille in a '76?
I think it'll bolt right in
10-05-2008, 12:20 PM | #3 |
Robert Olson Transport
it should screw right in .. but you may have to move or change the hood release or at least the metal rod on it.. check with captkaos he has a ton of knowledge in the interchange area
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 10-05-2008 at 12:22 PM. |
10-05-2008, 02:13 PM | #4 |
Dooce -
Maybe this will help... http://www.4wheeloffroad.com/techart...wap/index.html Pretty good article on this swap. - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
10-05-2008, 02:58 PM | #5 |
www.73-87chevytrucks.com
You have to have the 73-74 specific hood latch assembly and support along wth the tabs to mount the ends to.
It will not bolt into a 75-80 trucks.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-05-2008, 09:01 PM | #6 |
paper or plastic?
True, But its easy to fab up some brackets. I have a 73 grill on my 77 frontend. I'm in the process of instaling A/C right now and had to move a few things around though. I'll post some pics later
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
10-05-2008, 09:23 PM | #7 |
i'm going through this right now. i have had to swap the vertical support and bolt in the side brackets. i also have the cable release and i need to change out the release as well as the whole upper panel.
79 K10 77 MGB 79 Kawasaki KZ1000 |
10-06-2008, 12:56 PM | #8 |
did the same thing on my 79 and my 76 and my other 79. I kept the original grille, and center support up on the shelf, and swapped them back each time before I sold the trucks. Finally let it go on the last one. It was a factory black (not painted) 73 454 Grille.
Before: After:
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
10-08-2008, 11:25 AM | #9 |
yeller
I just did the swap last night on my 77. As stated, you will need the center support/latch assembly, and the outer triangular shaped brackets that sit near the headlights. You will also have to remove the vertical mid grill mounts because they will not work with the 73/74 grill. The 73/74 core supports have them built into the support, where the later models they are bolted in. This will be OK, as you still have the center and outer grill supported. You will also need to drill the 3/8" holes for the outer brackets, but they are located with center punches from the factory. The outer brackets will need to be mounted with nuts and bolts, as there are no welded nuts in this area on the backside to bolt them in to.
I'll post finished pics later.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 10-08-2008 at 11:27 AM. |
10-08-2008, 12:42 PM | #10 |
2bits thats amazing the transformation on that truck in the pics... gives the rest of us hope who started with the same kind of thing
10-08-2008, 05:07 PM | #11 |
You are going to share a write-up on this correct...
10-08-2008, 07:52 PM | #12 |
yeller
Yeah, I'll put one together. As promised, here are the pictures.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
10-08-2008, 09:32 PM | #13 |
That looks real good Jeff !
Bob, Thanks, yeah it was fun doing this one, within a week it went from needing to be crushed to down right presentable!
10-08-2008, 09:44 PM | #14 |
bigblock73....did you have a cable actuated release before the swap? i have one on my 78 and the 73/74 grill won't fit. did you swap the latch and the top panel or just the latch?
10-08-2008, 11:34 PM | #15 |
yeller
Bucket, no cable release..just the old fashioned exterior release....so the swap was easy.
Thanks for the compliments Thomas.
10-09-2008, 09:04 AM | #16 |
I wish someone would do a writeup on swapping a whole pre-81 front clip on a '81-up cab.
10-09-2008, 09:16 AM | #17 | |
10-09-2008, 12:51 PM | #18 |
Richard D
Here's a link to the "Chevy" search. http://www.4wheeloffroad.com/search/...archText=chevy - Dave
10-09-2008, 02:23 PM | #19 | ||
Interior release wasn't available for the 73-74's so you are looking at some fabrication to get that to work. Quote:
http://67-72chevytrucks.com/vboard/s...suburban+front Going in that direction is a simple matter of bolting the "doghouse" onto the cab. The only gotcha in going this direction is the frame horn on the 81-87 will have to be modified to fit the 73-80 rounded end for the bumper. My buddy just went through this on his 1975 truck we swapped the cab and bed from the donor 81-87 and he used 75-79 parts for the frontend and kept his 75 frame. Here is his post: http://forum.73-87chevytrucks.com/sm...p?topic=9396.0
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 10-09-2008 at 02:32 PM. |
10-09-2008, 04:39 PM | #20 | |
10-09-2008, 04:41 PM | #21 | |
10-09-2008, 04:56 PM | #22 |
OOPS, you wanted a 73-80 onto a 81-87:
this is the closest I can give you: http://forum.73-87chevytrucks.com/sm...p?topic=9396.0 As I stated above, it is a simple bolt on minus the bumper and wiper assembly. If he took enough pics (which I doubt) I will see if he can put a tech together, but it is simple by comparison to the 81-87 to 73-80 conversion. (I forgot to mention the wiper holes will need to be re drilled and the wiper assembly replaced with the 73-80 version.)
10-10-2008, 09:04 AM | #23 | |
'75, as claimed, or a '79-'80? |
10-10-2008, 11:34 AM | #24 |
The cab and bed are a 1984. The wiper assemby and the whole frontend is a 73-80.
The original 75 stuff was rusted so he got all new stuff.. (it is in the first picture.) I will see if he can post a pic of the wiper assembly, but it is pretty straight forward where they go..
10-10-2008, 06:42 PM | #25 |
Thanks Cap. I am swapping cabs anyway, so I'll probably try to find a pre '80 cab. But ya never know.
