10-05-2008, 01:55 PM | #1 |
up control arm shaft crossmember bolt
one thing after another it seems... when i removed the nuts holding the up control shaft in place, the threads were damaged. Is that bolt removable? some drawings from lmc catalog appear that it's pressed in or something? #8 in the image...
10-05-2008, 04:13 PM | #2 |
Re: up control arm shaft crossmember bolt
its like replacing the studs on your axle or hub, hit it with a big hammer to get it out. then use a nut and washers to pull the new one in.
1967 LWB 4speed-current project 1970 LWB 3 speed -stolen 1980 Z28 - sold 1968 Barracuda Big block- sold 1969 Firebird 400/400-sold |
10-05-2008, 04:33 PM | #3 |
thats how i did mine last weekend
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
10-05-2008, 06:12 PM | #4 |
Thanks everyone. This board is great. Although I've worked on vehicles my whole life, this forum gives me the support to try stuff I never have and share what I do know.
10-05-2008, 07:39 PM | #5 |
I bought the LMC bolts. Check out my post a few days ago. I'm now looking for another crossmember.
http://67-72chevytrucks.com/vboard/s...d.php?t=308904 |
10-05-2008, 10:09 PM | #6 |
what happened cobrajet21? Did LMC send an incorrect bolt that caused a problem such that it ruined the opening for the correct bolt? I imagine that if you put in a too large bolt, that would make it very difficult for the correct one, if it was a smaller diameter... that sux. i havent been all that satisfied with my limited purchases from lmc, but that would turn me off them for good.
10-05-2008, 11:02 PM | #7 |
the bolt in the pic is what they said was the replacement. the threads are the same the length is the same but the spline area is larger than the stock bolt and very hard to press in. it makes the hole too large for a stock bolt to go back into. some people on here were concerned that the smaller head on the lmc bolt might pull through after awhile and that got me nervous so i am going to get another crossmember and buy the correct bolts from performance online. it might not be a problem but i don't know.
10-07-2008, 09:37 AM | #8 |
sorry, the correct bolt is at classicparts.com not performanceonline.
10-07-2008, 12:06 PM | #9 |
my local chevy dealer still carried the bolt for about $4...
