door assembly?
My doors on the 71 are in bad shape. I;ve never run them on the rig since I got it and its getting cold and time to fix them u p. I cut the bottom of the door off (boatsided the rig they go on) and out cames a bunch of plates, spring, the door button, etc. is there a diagram to show how everything is supposed to be assembled inside the door somewhere? thanks
71 Blazer Build Thread
http://pirate4x4.com/forum/showthread.php?t=553755 www.powellvalley4wheelers.com |
Tasty Cakes!
Re: door assembly?
Something like this? Door
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
Re: door assembly?
kinda but not really. Both doors had a spring with a screw looking deal stuck in the end siting in the bottom of the door along with an oval plate and the door buttons. do the buttons just sit in the handle?
Re: door assembly?
It sounds like the door handles came apart and the parts fell down. The parts you are looking at were staked onto the door handle by bending tabs over the plate which held the plunger and spring. The door handle is a die cast part so getting the parts to stay in after the tabs break is usually not worth the effort. I would suggest getting different door handles and tossing the old ones.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
Re: door assembly?
i don't think its that bad. I can stick my finger in the hood handle button hole and push the lever and open from outside and the inside door handle works. Here are pics of the pieces I'm talking about. Not sure if the button just sits in there or what.
Too Dumb To Know Better
Re: door assembly?
That oval looking thing is the backing plate to a sport mirror. The little clip with the hole in the end goes on the rod that runs from your inside door handle back to the actuator. the other 2 items belong to the door handle. Pick up a used pair of handles on the parts board. Since your wheelin yours, they don't need to be all shiney.
Re: door assembly?
is there any way to just put the parts back in or are they broke?
Re: door assembly?
Broken. Sad, but true.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Re: door assembly?
doh. Both my door handle look like this too.
see if I can fond someone who replaced rusty ones i guess then
http://pirate4x4.com/forum/showthread.php?t=553755 www.powellvalley4wheelers.com Last edited by MNorby; 10-11-2008 at 07:58 PM. |
