10-05-2008, 07:15 PM | #1 |
Is the clutch adjustable.....
On a 86 one ton hydraulic clutch. My Dad bought a wrecker, The guy he got it from put in a new clutch and the works. I got in it the other day to move it, and you just barely let the pedal off the floor and it's grabbing. I like my clutch's to have more of free travel before they start to engage. So if you guys can help me out , I'd appreciate it.
If you need more info, Tell me and I'll try to get it for ya's.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
10-11-2008, 08:28 PM | #2 |
Re: Is the clutch adjustable.....
TTT, if anybody can give me any idea. Id appreciate it
10-11-2008, 08:40 PM | #3 |
Georgia Boy
Sounds like it might need to be bled.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi. |
10-12-2008, 04:55 PM | #4 | |
Art 1975 c-10 stepper 1978 single cab dually 1987 crewcab dually 1986 crewcab single wheel 1948 anglia- (the dixie twister super gas) Last edited by gafiredog; 10-12-2008 at 04:58 PM. |
10-12-2008, 10:25 PM | #5 |
Just here to tinker
There should be an all thread stud going from the slave cylinder to the shift fork. There are two nuts on there, and the one closest to the S/C should be welded. The other nut is at the S/F end and is adjustable. Probably two 9/16 wrenches and a little patience...
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
10-14-2008, 09:13 PM | #6 |
Ok, thanks for the tips, I'll give a look, to see what I can do.
10-14-2008, 10:28 PM | #7 |
For what its worth (not so much if you know the stores), Autozone.com has repair info. Sort of like online manuals and it says there's no adjustment.
10-16-2008, 10:23 PM | #8 |
I went out this evening to look at the S/C rod. there's no adjustment there. I did find out the the S/C was considerably loose. So I tightened it back up, but was unable to see if that fixed my problem, because the battery was dead. I have the battery on charge, so I'll check to see if it's any better tomorrow.
10-16-2008, 11:44 PM | #9 | |
Just here to tinker
10-17-2008, 11:18 PM | #10 |
Well it still grabs alot soonerthan I would like, but it is better than it was. Before you could barely lift there was no time to feather the gas to get going. Now there is a little room to work with but very little.
10-18-2008, 12:51 AM | #11 |
Just here to tinker
I guess the only other option is to bleed it then...
