Old 10-05-2008, 08:32 PM   #1
dan42
dan42's Avatar
Heater box question
I found a heater box at the junkyard, and the guy that pullled the the part (a non-A/C box) busted off the flange where there should be a bolt holding it to the firewall, but it's the one that people leave out anyways, so they don't have to drop the inner wheel well. Doeas anyone know if this will work O.K. or should I find another one? I'm wondering about the seal. The seal area is actually O.K.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 10-05-2008, 08:53 PM   #2
jkaylor68gmc
jkaylor68gmc's Avatar
Re: Heater box question
I have one in great shape you can have for 10 bucks and the shipping if you want.
Not to try and sell you, but there may not be enough pressure there and tightening the other bolts may cause that side of the lip to raise.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 10-05-2008, 08:58 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'd roll with it. You probably only use your heater for a month out of the year anyways.
Old 10-05-2008, 09:52 PM   #4
dan42
dan42's Avatar
That's true, but I'm getting tired of using a towel as my defroster. Almost every moring it's dewey here.
Philippians 4: 6-7
Old 10-10-2008, 10:51 PM   #5
smoked68
smoked68's Avatar
Changed mine last winter, broke off the same by accident, I used the Black permatex RTV all the way around and have had no problems. Good luck, Mike...
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 10-11-2008, 12:26 AM   #6
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Exclamation Re: Heater box question
I'd use it, mine has been like that for years and I have never had a problem with it!! P.S. Don't use Latex caulking or silicone to seal it, it causes rust I learned it the hard way!!!! 3M makes a black strip caulking that is the way to go!!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 10-11-2008, 06:38 AM   #7
70GMCer
70GMCer's Avatar
curious....how does latex or silicone cause rust, when the heater case is plastic??
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
