Old 11-21-2002, 02:13 AM   #1
cheyenne10
cheyenne10's Avatar
help with frame repair
Will a frame notched for headers just behind motor mount affect its strength? Can the notches be hidden or fixed to regular rail again? I would assume a very good welder could cut out enough material and make a matched patch and fit back in to look like new. Any thoughts on steel integrity in this area? I would wnat to finish frame and have showy engine compartment. I'm not a header fan, stock manifolds are for me!!
Bob
cheyenne10 is offline   Reply With Quote
Old 11-21-2002, 09:19 AM   #2
JimKshortstep4x4
Smile
Not knowing what the notches looks like or whether access to the areas is available, my thoughts are, yes it can be fixed and more importantly it should be fixed. When they notched it did they reenforce it? I assume not.
A good welder could fabricate a piece and weld it in with good results if he can get at it. The weld areas can be ground down,
smoothed and painted with good results.
Jim
Old 11-21-2002, 09:40 AM   #3
crazy longhorn
Fabricate till you "puke"
I have a small notch ea side on the bottom "lip" of the frame(scars for header clearance on a BB Olds)...... as long as they arent too deep, they wont hurt the strenght of the frame. Mine are approx 1/2" deep x 1 1/4" long.......Im gonna leave em , for future insanity(still have enough parts to build 3 more of those Olds monsters)......
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-21-2002, 12:52 PM   #4
cheyenne10
cheyenne10's Avatar
bare frame
Frame is bare. I asm still looking at pics myself and not sure how big nothces are. At least the one notch I know about is supposed to be ontop of passenger frame rail adjacent to header location. Looks like rough torch job. I've seen two like this lately. I don't want to be too picky but I don't have a welder or the skills. If I could pay competent welder for an hours labor and get done nicely it might help.
Bob
Old 11-21-2002, 01:08 PM   #5
crazy longhorn
its hard to say without a pic, but if they are big notches, & or you plan on showing the truck, a good welder/fab guy could grind them smooth & weld a patch in. I would suggest using a mig or tig welder to control the amount of heat in the weld area. Good luck....crazy AL
Old 11-22-2002, 01:43 AM   #6
cheyenne10
cheyenne10's Avatar
pic of frame trim
Hopefully here is frame rail wiht cuts. I am looking for advise.
thanks.
Bob
Old 11-22-2002, 01:46 AM   #7
Hooter
My other Love
Hooter's Avatar
I cant really see where the notch is?
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 11-22-2002, 01:58 AM   #8
cheyenne10
cheyenne10's Avatar
I tried to circle it
See above. I tried to show it (crude I know but I'm proud I got it posted tonight!!)
Bob
Old 11-22-2002, 12:34 PM   #9
cheyenne10
cheyenne10's Avatar
ttt
Any welders comments?
Bob
Old 11-22-2002, 12:48 PM   #10
Erl
Erl's Avatar
This cut-out will reduce the strength of your frame. Fix it period. I have 3 engineering degrees and deal with this type of thing on a daily basis.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 11-22-2002, 09:34 PM   #11
jerry moss
Born Psycho
jerry moss's Avatar
Bob,
if you do all the grunt work yourself it will save you some money.clean the hacked up area with a small grinder, cut the patch pieces out of another frame and trim to fit. be sure to bevel the edges so you get good penetration when it gets welded. after it's welded top and bottom, you can grind the top weld smooth for a clean finish.
i have a section of frame out back that's about 16 inches long, it's the steering box mounting area off a 72 2wd. if you give me your measurements i'll take it to work and cut some patch pieces with my plasma cutter. i did this same fix on my cousin's 72 3/4 ton 4x4 and once it's cleaned and painted it looks good as new.send me a P.M. or you can shoot me a call at 925-634-2512.
hope this helps.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 11-23-2002, 06:59 PM   #12
cheyenne10
cheyenne10's Avatar
thanks
Thanks Jerry Moss. I will get back to everyone if this works out.
Bob
