Moderator
![]() Join Date: May 2007
Re-Dying Seatbelts
I have a set of red shoulder harnesses/buckles that I would like to re-dye to match the factory medium blue color of the interior of my truck. I am sure some of you have done this. Any suggestions on stuff/techniques?
Moderator
Re: Re-Dying Seatbelts
Here is what my factory seatbelts look like.
Burnouts are therapeutic
I tried doing it on a set of belts in a car I restored because they didn't make new belts at the time ,I used spray die and it ruined the belts they were stiff as a board I'm sure theres a right way to do it but the method I chose was not it .....hopefully someone who had a good experience will help you out with the proper way
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
Moderator
Thanks...I have not had luck with the spray dye in the past with seatbelts. It works great on plastic, but not fabric. I ethought of going with that Rit liqid dye you can get at any store...
"GO DAWGS"
I have used the rit dye but on black belts. If you can find the dye in that color which I doubt you can, it works great.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
Junior Member
![]() Join Date: Mar 2007
google Rit dye. you can make custom colors by mixing the dyes...
frontstreetcycle on Instagram |
Out of the carpool lane.
The potential problem with Rit dye or anything else is that you don't know what it's doing to the integrity of the belt material. I wouldn't want to find out that it was a bad idea at the last second.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Moderator
Looks like Rit all the way...
well i got my 67 chevy truck seat belts from a guy in TN they where blue and in greart shape i paid $50 for them if any one whats
the # send me a prive message |
Hand Crafted C-10
![]() Join Date: Aug 2006
Maybe put a "want to swap" on the parts board; you get blue belts, they get red belts...
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
"GO DAWGS"
He is not gonna swap shoulder belts
![]() PT
Moderator
#13 |
i'd think to dye those red belts blue you'd first have to try bleaching the red out/then dye them blue// i doubt the dying process would affect the belts but the bleaching process would worry me
if i were to do it i'd search and try and get the correct size and color webbing and transfer the original ends onto it
#14 | |
Moderator
#15 |
still buypickupparts
the strengh of seat belts???? I use the same one for years to lift and install engines all the time, never a fatality. built like a rock CHEVY
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
#16 |
![]() Join Date: Aug 2008
I work at a linen plant were we wash sheets, table clothes, napkins, pretty much everything in a hotel or restaurant. Occasionally we will do a dye and re dye table clothes. It is extremely hard if something isn't right it gets all messed up. I have never tried it on anything like seat belts. But when I do it at work I run a bleach cycle first, sometimes even twice. Then I run the dye cycle it takes about 200 hundred degree water too. If I were you I would look into buying new ones. Just my 2 cents
#17 |
I tried to spruce up a blue set of belts using Rit and couldn't ever get them to look right. I even used several different shades of blue but they just never looked like they did originally. I would like to here about how the bleaching process turns out, keep us posted.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#18 | |
Moderator
#19 |
![]() Join Date: May 2008
I needed belts also and my interior was hugger orange. I bought used tan ones. I took them all apart. I bleached the belts numerous times until they were white. I used Rit dye in red and again in orange. I used boiling hot water and did it outside in a bucket. The finished belts and buckle were so clean and shiny that I used a weak bleach solution to fade them slightly. Alot of time but they match the interior. The integrity of the belt is NOT compromised!
Mine is chopped, has a clutch, and a big block. |
#20 |
You might want to contact Jerry Brown at The Truck Shop, I believe he restores belts in most colors, I remember seeing rolls of seat belt material while I was there.
www.thetruckshop.com The catalog lists the service as $175-225, but I think that's for a full set. Just two shoulder belts should be cheaper???
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html Last edited by powell72; 10-12-2008 at 05:34 PM. |
#21 | |
Moderator
#22 | |
Moderator
#23 | |
Moderator
#24 |
I totally understand, if it was me I'd be doing the same as you. Always gotta throw out all the options though.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
#25 |
Moderator
OK, here is what I have come up with after carefully bleaching, drying, and re-washing with fabric softener. I think they have turned out pretty well. They are slightly yellow at this point (due to the bleach) I am now ready for the final wash with Rit color remover to whiten them up a touch more, and then the actual dyeing process will begin. Note how the color did NOT come out of the rubber boots.
