Old 10-06-2008, 04:56 PM   #1
steverino66
having half a fit with big block headers
Test-fit the headers today on the 454.
Passenger side just touches the frame - no problema.
Driver's side needs another 1/2 inch to clear tower on the bottom of the #1 tube.
Don't really want to get out the big hammer - will the tubular aftermarket towers solve this problem? (current towers are small block with the hole elongated slightly to line up with the mount on the engine)
I know some of you guys have solved this problem - help will be appreciated.
steverino66 is offline   Reply With Quote
Old 10-06-2008, 05:43 PM   #2
kizer
Its Deja Vu time again
kizer's Avatar
Re: having half a fit with big block headers
Wow I'll never look at my L6 250 the same. Thats a big motor my friend.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 10-06-2008, 05:58 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
if you want total clearance without cutting up a mount you can use these mounts. And this is my big block build thread http://67-72chevytrucks.com/vboard/s...d.php?t=259536
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 10-06-2008, 11:49 PM   #4
Captainfab
60-66 Nut
When I did my Burb,I used headers for the '73-'87 trucks. I trimmed the top flange of the frame rail on both sides, using a '73-'87 frame as a template. As for motor mounts I again used the '73 and newer mounts with custom built brackets. It looks like the tubular ones that Chevy Fleetside used would be the solution to that problem for you.
Old 10-07-2008, 01:21 AM   #5
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
this must be the "to much work" you described in my thread
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 10-07-2008, 10:10 AM   #6
steverino66
Fleetside -
Or anyone else - who makes the stock-looking mounts in your first pic? I've found the tubular type kit at Brothers but would rather go with the first type if possible.
Thanks for the other replies - I'm stuck with the earlier style (up to '72) headers.
Old 10-07-2008, 10:22 PM   #7
Chevy Fleetside
Originally Posted by steverino66 View Post
Fleetside -
Those are the same mounts you have in right now. I would have had to cut to much of the left mount away to be able to use them. I tried many mounts and the tubed ones worked the best. I just didn't like the way the 73 and up mounts looked is all but they would have worked also. I also cut my firewall so I could scoot the engine back as far as possible.
Old 10-07-2008, 11:09 PM   #8
steverino66
I saw some stock-looking towers advertised on Craigslist (the guy doesn't want to ship them apparently) supposedly for 60-66 - thought maybe that's what you had there; can't find any aftermarket except the tubular.
I have some 83 towers, will have to buy the other style mounts, but I'll give those a try to save the $140 for the tubular kit.
Thanks again.
Old 10-09-2008, 11:57 PM   #9
Captainfab
60-66 Nut
No, No....I was just joking with ya. It's not really that much work IMO. It's mostly just knowing what to do.
Old 10-10-2008, 12:02 AM   #10
Captainfab
60-66 Nut
I didn't realize that is what headers you have. In that case you should be able to just switch out your current motor mount frame brackets with some '69-'72 big block frame brackets. They are made such that they have an indent on in the top area to clear the exhaust manifolds, which should work with the headers since that is their intended application. If you need a pic let me know.
Old 10-10-2008, 12:39 PM   #11
steverino66
Thanks, Captainfab - I already have a set of those on the way (scored on craigslist)
Old 09-03-2015, 04:57 PM   #12
scoots71
What kind of headers are you using
scoots71 is offline   Reply With Quote
Old 09-03-2015, 05:04 PM   #13
Chevy Fleetside
http://www.summitracing.com/parts/he...olet/model/c20 They sure did go up in price. I would use the 3/4 chevelle headers. These hang down pretty low.
Old 09-03-2015, 06:54 PM   #14
ol_skool_chevy
ol_skool_chevy's Avatar
what year 3/4 chevelle headers would you use???
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 09-03-2015, 08:04 PM   #15
Chevy Fleetside
Here are some shorty headers for a 70 Chevelle. I am not 100% sure if they will work. Someone on here dose though. I would probably order one of the shorty headers. If they didn't fit I can always send them back. I'm sure someone will chime in with the right answer.
Old 09-04-2015, 01:19 AM   #16
Captainfab
60-66 Nut
No need for shorty headers.
http://www.67-72chevytrucks.com/vboa...d.php?t=533692
Old 09-04-2015, 04:25 PM   #17
Chevy Fleetside
Well there you go. I will go this route later on.
Old 09-28-2015, 06:51 PM   #18
scoots71
the stock big block towers should fix that they dip down to give clearance
