![]() Join Date: Oct 2001
poly tank for pickup???
Several yrs ago I bought a poly tank for our project "ORANGE" and it's about time to drop it into the rear frame rails! My question to my friends is the tank comes with 3 vent tubes and the truck is a carb. engine not FI so has any of you installed one of these tanks with sucsess and if so which line should be used and which can be plugged off ??
Thanks guys, just want to get it right the 1st time! Pic.s would be great for me also.........
Things happen for a reason! |
![]() Join Date: Oct 2007
Re: poly tank for pickup???
ttt
I am in the same situation so, I thought I would bump this up for an answer. Thanks in advance! |
Future TOTM Winner
You basically only need 3 ports...1 large one for the filler neck, 1 for the output to the fuel line, 1 overflow that runs back towards the filler cap. Any additional vents are ok as long as they don't let in dirt. Keep in mind most normal fuel caps allow for ventilation. This might help
http://67-72chevytrucks.com/vboard/s...d.php?t=291111
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 10-07-2008 at 11:50 AM. |
dose any one know where i can find the round gas tanks that go on the out side of the frames of the 3/4 ton and one ton trucks
