Old 10-06-2008, 10:13 PM   #1
mobileortho
mobileortho's Avatar
Low $ shroud......don't laugh!!!!
With todays financial crisis, my budget for the truck has been virtually eliminated so I've been looking for some creative ways to save some money. With that in mind I came up with a low budget, low tech fan shroud.This is what I came up with. It's two 17x11 baking sheets I got from Walmart for $10. I cut off one side of each one, traced and cut out the hole for the electric fan and bolted the halves together. I then bolted the fan over the hole and used plastic ties to secure it to the radiator. It works good considering what it's are made of and there is plenty of clearance. I know I'll more than likely replace the radiator & get another shroud eventually, but for now I'll use this setup! Stop laughing!!
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 10-06-2008, 11:25 PM   #2
49gmc
49gmc's Avatar
Re: Low $ shroud......don't laugh!!!!
i think its awesome dude. shows some good ingenuity
__________________________________________
-1949 GMC 100 longbed
-1972 chevy c/20 suburban
-1982 chevy k-5 blazer
49gmc is offline   Reply With Quote
Old 10-07-2008, 03:02 AM   #3
Swifty
Swifty's Avatar
thats awesome! would look/work great on a ratrod/patina style truck.
Swifty is offline   Reply With Quote
Old 10-07-2008, 07:31 AM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
That worked out very well .....
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 10-07-2008, 09:08 AM   #5
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Robert:
That looks better than most factory made shrouds. Don't tell anyone what you made it from and they'll think you paid big bucks for it. "Way to go Buddy!"
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 10-07-2008, 10:15 AM   #6
robin58
That's ingenious. But how come ya didn't go for super-savings and raid your wife's kitchen? "Honey I have no idea where you could have put your cookie sheets"
robin58 is offline   Reply With Quote
Old 10-07-2008, 11:42 AM   #7
Swifty
Swifty's Avatar
LOL, i can only imagine what she would do! i think mine would kill me! or knowing my luck i'd get busted walking out of the kitchen with them in hand.
Old 10-07-2008, 11:45 AM   #8
solidaxel
solidaxel's Avatar
You may want to add some 2 X 2 releif holes in the corners to let the ram air flow out at highway speeds. Looks like it will work just fine!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 10-07-2008, 02:18 PM   #9
mobileortho
I enjoy living!
Robert C.
1950 3600
Old 10-07-2008, 03:20 PM   #10
tommypic
tommypic's Avatar
I bought about 13 of those at a storage auction for 3 bucks . I might be able to make a lick
My ZipCode = 29673
2008 Silverado Z71 LTZ Wrecked New Ride SOLD
71-72 Custom A/C Parts Truck < selling parts
67 Chevy ShortStep SOLD
67 GMC SWB Step <-- For Sell
67 Chevy SWB Step <-- working on
2000 Road King <-- SOLD
97 F150 my ride for now
2006 Escape wifes ride
HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php
Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2
tommypic is offline   Reply With Quote
Old 10-07-2008, 03:54 PM   #11
entourageguy
Yellow truck club
and they're adjustable...
for the rat rod look you could used the ones in the kitchen and buy the wife some new ones...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 10-08-2008, 06:56 PM   #12
Arkansas50's
Arkansas50's's Avatar
And non stick thanks to Teflon!
Arkansas50's is offline   Reply With Quote
Old 10-14-2008, 01:43 PM   #13
tylordurben
tylordurben's Avatar
nice! i did this earlier this year on my 51 Buick... if you dont mind ill post up how i did it...
alright, i got 2 Stainless Steel pans from the kitchen not exactly the same but used wisely nobody will know. so let me show you what i have done.
first pic is the steam table pan, this one is deeper while the other was not so much:
so i cut out about 1.75" of depth and one long side to flatten off the other side:
here is what is left of the pan after cutting the section for the shroud, this i am using to extend the shroud surface in all directions, simply sectioning it but backwards:
now you can see a mock up on the rad and how the above missing piece is used to extend the surface area:
taped up the whole thing with some cardboard so i could pull it out from the rad and locate the fan. i used a push pin and string to make the circle which i later used striping tape to mark. all the parts are layed out with the fan possitioned in the center:
ps i do not have a means to weld SS so i have to design without welds.
top view without fan:
here is the mock up pic (crappy pic i know):
got the metal i will use for the sides and made / mocked up the barrel. think it needs a little rubber cause the barrel doesnt sit completely flush against the cut circle, from the pic it looks perfect but in person it isnt, its close but not perfect.
i think im about done!
the top side is the nicer part the bottom has some dings from the original pans, i think it looks great, i bent the two side L mounts and riveted them on so you dont see the conection:
tylordurben is offline   Reply With Quote
Old 10-14-2008, 01:43 PM   #14
tylordurben
here you can see the small rubber vacuum hose that i slit, it really helped finish the edges:
the back side so you can see the rubber hose and how little it will obstruct if any the airflow:
what do you think?
Old 10-14-2008, 01:48 PM   #15
bad6772
Official Site Guitar Shredder
bad6772's Avatar
i think you did one heck of a job.....And considering you did not weld anything to make this.....I say JOB WELL DONE........
bad6772 is offline   Reply With Quote
Old 10-14-2008, 09:26 PM   #16
mobileortho
Great minds think alike!! Good job!
Robert C.
1950 3600
Old 10-14-2008, 10:31 PM   #17
BlueBowtie
BlueBowtie's Avatar
Hey, mobileortho, you're on Classic Parts forum. I saw this several days ago, and I thought it looked good. Nothing wrong with low budget ingenuity.
http://www.cardomain.com/ride/3110793
1951 3100 RCSB
2000 K2500 CCSB
BlueBowtie is offline   Reply With Quote
