brake booster question?
I am replacing my master cylinder cause leakin from rear and where it bolts up to booster i noticed the pushrod coming out of booster was all wet and rubber gasket cracked! Is there a oring set for this or do i need a new one cause LMC does not show oring for booster! thanks would appericate the help and new to site and look fwd to visiting more!
Re: brake booster question?
Wish I could help but I'm not sure on this one. Only thing I can suggest is hitting your local parts house & look @ a rebuilt booster & see if there's a seal on them that you might be able to pick-up separately.
At least this will get moved back up to the top for ya if nothing else. Welcome to the site BTW!
no fluid in booster. the fluid is coming from the rear seal on master cylinder.
