Old 10-07-2008, 02:26 PM   #1
454HO
which rear could this be?
Found an ad for a complete '78 Chevy truck rear end that supposedly has 3.55 gears. I've looked at the aftermarket gear makers and none of them have 3.55 for 10-bolt, 12-bolt or 14-bolt Chevy truck rear end housings. Was 3.55 a factory gear? What would be the most common housing it is in? What is the likelyhood it would have a posi carrier?
- Greg
454HO is offline   Reply With Quote
Old 10-07-2008, 04:29 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: which rear could this be?
3.55 wasn't a factory gear ratio, if that is what you are asking about. On a 12bolt it is 3.42 and down and above 3.42 for the split. I have no idea what the 3.55 would fit, but I would assume it is has a spacer it would be for the 3.42 down and if not it would be 3.42 up.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 10-07-2008, 04:45 PM   #3
Jonboy
Slots go on anything!
If they really are 3.55 gears, it is probably a Ford rearend.
Old 10-07-2008, 08:09 PM   #4
454HO
Well I sent the guy an email and tried calling the phone number posted in the ad. No response yet.
I did some more research and found that a 3.55 gear is common for both a 8.2" 10-bolt and a car 12-bolt. If this turns out to be a car 12-bolt, I'm definately snagging it. And yes, this is a common ratio for Ford 8.8" and Mopar 8.75" too.
- Greg
