10-07-2008, 03:09 PM | #1 |
Will it work??
Hey guys,
Looking for some advice from the tire experts here. I have a set of 17" centerline wheels. Fronts are 17x8 with 255/60 rubber. Rears are 17x10 with 275/60 rubber. Tires need to be replaced soon. I want to go with a smaller set both front and rear. I know someone that has a set of 235/55/17s for sale. CHEAP. My question is will these tires fit on the 10" wide rear wheels?? I'm thinking they may be too narrow but not sure! Whatda ya think??
1990 Chevy Suburban 1/2 ton 2wd 1988 GMC Suburban 1/2 ton 2wd |
10-07-2008, 05:48 PM | #2 |
Georgia Boy
Re: Will it work??
235s are too narrow for 10" wheels. The sidewall will be splayed out too much.
10-08-2008, 11:46 AM | #3 |
Re: Will it work??
Yeah, I was afraid of that. I want to come down about 2 inches in diameter. The 275/60s are 30" diameter. What size tire can I use on those in order to get closer to 28"?
10-08-2008, 12:21 PM | #4 |
Chevys Kick A$$
Re: Will it work??
Yea I gotta agree and say those ones you want aint going to work. Thats a bummer though.
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
10-08-2008, 12:29 PM | #5 |
1962 C-10
Re: Will it work??
I'm not sure what the diameter is in inches, but I used to have a '93 with 17" Centerlines. I ran 255/45r17's in the front with 8's, and and 275/40r17's out back with 10's. It was the perfect combo...
Joseph Chavez "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
10-08-2008, 04:28 PM | #6 |
67-72 parts collector,…
Re: Will it work??
Run 255/50-17's on front and 275/50-17's on the rear. Look at Nitto tire. (the 450 series) These tires should be 27" and 28" tall.
10-08-2008, 05:13 PM | #7 |
Re: Will it work??
05-13-2009, 06:42 PM | #8 |
Re: Will it work??
other than looks, is there another reason for the smaller front tire size? is there a clearance issue or could you run a 275/50/17 front and rear?
-mike |
05-14-2009, 02:40 PM | #9 |
Re: Will it work??
you said you had 8" fronts and 10" rears so it not like you can rotate them.
its the look 275 on 8" wheel will bubble out and 275 on a 10" will be pretty strait so for consistancy it might look funny with the rears side walls strait and the fronts bubbled out. as long as you don't have some crazy offset you can run 275 in front no problem. |
