10-07-2008, 07:36 PM | #1 |
van tilt
i just got my van tilt and i was looking at it and i noticed that there is no turn signal switch what does this mean am i in trouble because this is not there what do i do? help please
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 Chevy Trucks the longest lasting most dependable trucks on the road |
10-08-2008, 12:25 AM | #2 |
TILT COLUMN GURU
Re: van tilt
Switches are still available. Are mounting screws missing also? that may be a problem. they are unique for tilts.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
10-08-2008, 12:25 PM | #3 |
Re: van tilt
i will shoot some pics
10-08-2008, 10:32 PM | #4 |
Re: van tilt
10-08-2008, 10:44 PM | #5 |
Re: van tilt
Bring it buy the house and we will compair it to mine and see what all is missing. I would get the new switch any way and I think we can make the stuff from your non tilt work even if we need to modify or retap a screw hole or somthing we can get it done. I totaly rebuilt mine when I got it, new barings and every thing I wanted to besure I didnt have to mess with it again.
Earl 68 2500 4x4 GMC Burb |
10-08-2008, 10:44 PM | #6 |
Re: van tilt
I'm not trying to be a smart a$$ but if you put your digital camera on the flower setting it will take close up pictures more clearly. I just learned this a few months back myself. It may be some other symbol besides a flower. Depends on the camera brand I guess.
10-08-2008, 10:54 PM | #7 |
Re: van tilt
it looks like my turn signal switch is just broken off
10-08-2008, 10:55 PM | #8 |
Re: van tilt
is it missing the pointer thingy?
10-08-2008, 11:10 PM | #9 |
Re: van tilt
your missing the pointer thing but the one from your old colum should work and you can still buy those if needed.
10-09-2008, 01:42 AM | #10 |
TILT COLUMN GURU
Re: van tilt
All you need for that column is turn signal Lever. Pointer is different from fixxed column to tilt column but both are available from Early Classic Ent. You will also need to take left turn cancell spring from your original column and install it in your tilt.
Or if you want it all ready to install buy one of these. Check Link http://67-72chevytrucks.com/vboard/s...d.php?t=264748
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY Last edited by KevsClassics; 10-09-2008 at 01:57 AM. |
10-09-2008, 09:24 PM | #11 |
Re: van tilt
so what all do i need to buy i have got the tilt turn signal switch comeing but i know that i ned a tilt lever but what else?
10-09-2008, 09:28 PM | #12 |
Re: van tilt
ok i looked on early classic and didnt find what i needed
10-09-2008, 09:41 PM | #13 |
Re: van tilt
will the 71-72 tilt pointer work cause i am going to order them
10-10-2008, 12:08 AM | #14 |
Re: van tilt
it should work just fine. I think your old lever will work too. When I got my parts I got them all from Wes as classic heart beat. I got the pointer and all the barings from him.
10-10-2008, 12:18 PM | #15 |
Re: van tilt
ok well i will try and get ahold of him
10-10-2008, 01:28 PM | #16 |
Re: van tilt
Tim should be able to get them for you to if you want to go pic them up at his shop.
10-10-2008, 07:50 PM | #17 |
Re: van tilt
yea that was something else that i was thinking about doing as well
