Project 7dos
Trouble Starting
My truck is wierd...When it is cold it will start up just fine, but when i drive it and it gets to about 190 degrees, it hates starting back up again and sometimes won't even start, it isnt a battery because we just bought the battery, Could it be my Distributor or my Starter, I DONT KNOW!!!!!!
Thanks Jason ![]() ![]()
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
350s are notorious for doing that, especially the ones with headers. You may have to install a heat shield on your starter.
sounds like a starter problem to me....the shielding in the starter when it gets hot will expand and if the wiring is weak wont carry the voltage nec. to crank the truck...and when cold everything is back to normal and will start....2 options...
1) replace the starter 2)drive very short distances and not let the starter heat up !! hope this helps
94 K1500 SWB w/ 4" body and suspension lift |
does it crank or just do nothing. what kind of exhaust are u running. what kind of carb do u have. edelbrocks will allow the fuel to basically be evaporated.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
