10-07-2008, 09:22 PM | #1 |
It followed me home?
Tranny swap ?, I searched ...
Sorry for the dumb question, I searched but apparently I am search function slow ha ha.
I would like to swap the th350 for a 700r in my 86 lwb k20 w/np208 t-case. Other than the tranny itself what else is needed? Thanks
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
10-07-2008, 09:26 PM | #2 |
Robert Olson Transport
Re: Tranny swap ?, I searched ...
for sure youll need the different indicator thing on the dash
10-07-2008, 09:28 PM | #3 |
ha ha, thats the only thing I was sure about.
10-07-2008, 09:33 PM | #4 |
Georgia Boy
You might have to relocate the crossmember and/or get a different one since it's 4x4.. not sure though. The crossmember had to be moved when my truck was swapped from a 350 to a 700.
10-08-2008, 08:08 AM | #5 |
Slots go on anything!
I am pretty sure it is a bolt in affair. Since your truck is an 86, all of the necessary holes should be in the frame if the crossmember does need to be moved. The Th350 thould have a TCC also, so that will plug in. The bracket for the kickdown cable is the same to hold the 700's TV cable. I don't remember the output shafts having different splines, but it has been over 10 years since I have had a 4WD. If you found a 700/208 combo for sale, it would bolt right in for sure.
10-08-2008, 09:38 AM | #6 |
Are you going to use your old Tcase?
-Lincoln 1987 GMC S15 (soon to be a chevy clone) 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. Spoken by Cletus the hillbilly I like stickers... a whole bunch. |
10-09-2008, 11:34 AM | #7 |
STOP! Hamma time!!!
I haven't done such a swap, but don't you have to get a shorten drive shaft? It was my impression that the 700R4 was longer than a th350 or th400.
Plan your work and work your plan!!!, or pitty da fool!! 87 GMC BaseTrim, 305 under the wrench/TH400/ 92 Chevy 1500, 350,TH700R4 sittin on dubs |
10-09-2008, 08:33 PM | #8 | |
That was the plan
Thats what I thought, I dont have a 700 here to measure though. I figured more people here would have done this swap?
10-09-2008, 08:37 PM | #9 |
Georgia Boy
Between a TH350 with a 9-1/4" tail and a 700 there is only a 1/8 difference.
10-09-2008, 09:33 PM | #10 | |
Thanks everyone
10-10-2008, 09:16 AM | #11 | |
I was curious about the transfer case as I figured it might be easier to find a 700/208 combo pretty reasonable, and then you would know the splines would be the same. Last edited by Jonboy; 10-10-2008 at 09:17 AM. |
10-10-2008, 01:45 PM | #12 |
The input shaft splines might be different on the Tcase. I'm not sure though.
-Lincoln 1987 GMC S15 (soon to be a chevy clone) 2.5l, 4 speed, no ps, no pb, no ac Silence is golden, but duct tape is silver. Spoken by Cletus the hillbilly I like stickers... a whole bunch. Last edited by abebummy26; 10-10-2008 at 01:46 PM. |
