Old 10-07-2008, 11:25 PM   #1
Momboy007
HEI Upgrade for 69 396
Hello All,
I am considering removing the point distributor on my 396 3/4 ton truck, what do you all recommend? I do not want performance just reliability. The truck also has factory AC, will this be a problem? If I go to a junk yard, do I need a big block distributor?
Any help would be greatly appreciated
Rick
Momboy007 is offline   Reply With Quote
Old 10-07-2008, 11:42 PM   #2
dan42
dan42's Avatar
Re: HEI Upgrade for 69 396
A/C should not affect the dizzy. I don't recommend going to a junkyard for a dizzy, you'll just trade your problems. I got one off Ebay for less than $100 for my 350, and it works great. I can't remember the name, but I think it's Bill White.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 10-08-2008, 12:29 AM   #3
Momboy007
Is a Small Block and Big block Distributor the same?
I guess what I mean is can I use a small block dizzy on a Big Block?
Thanks,
Rick
Old 10-08-2008, 07:26 AM   #4
JimKshortstep4x4
Small block and big block distributors are the same. You can use a small block distributor in a big block.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 10-08-2008, 07:31 AM   #5
rscam
I hope this is the last time Snoop Dog comments on a thread.
rscam is offline   Reply With Quote
Old 10-08-2008, 09:29 AM   #6
Willys47
Willys47's Avatar
This was posted on a nother thread and it could apply to this one as well
Re: HEI Replacement on 69-ish 292
Missing from all the above discussion------- The advance curve for most engines designed for HEI can be quite different than your engine.... By all means, have the HEI weights and springs adjusted to match the ignition curve for the engine that the HEI will be installed on. Shops that have a distributor machine will match the curve for your engine...This will then give maximum performance and fuel economy.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
