FACTORY AC - Are all years identical?
Think I'm going to add factory AC as part of my 70 K10 build...So, I'm going to look for a donor truck that has it.....I'm just wondering if I need to look only for a 70 or will any 67-72 factory AC truck be ok?
Hopefully I can find a donor that has the AC plus "Buddy Buckets"....and I will be one happy dude ! Thanks, Dan Last edited by Rack Man; 10-07-2008 at 11:48 PM. |
Re: FACTORY AC - Are all years identical?
so far ive seen most of 71 or 72 trucks with a/c ive seen 67-70 trucks that had a/c before i would like too find a/c for my 67 chevy 3/4 ton long wheel base 4speed truck i do have a spaire dash that has the holes for factory A/C
It's a catastrophic success.
![]() Join Date: Jan 2003
I believe that the units were all the same. You will have to modify the firewall a little because of the differences and dash vents
A/C box mounting holes are also different. Installing an a/c system from a 72 GMC in a 68 Chevy now. I had to elongate the heater core holes, and drill the holes for the a/c box. The difficult part will be locating the brackets for the vaccum operated wiper cowl vent correctly.
Mike Redpath |
![]() Join Date: Jan 2002
We added factory air to our 68 gmc. The nice thing about it is, as shown in the picture, is that you can make the holes bigger and the a/c box will cover it and you won't have to cut out the firewall and replace it.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
#6 | |
Old Skool Club
![]() Join Date: Jun 2001
As an aside, as soon as my cab goes into the shop to be repaired, I will be removing an air dash from the scrap that I will be left with. It is un-cut, meaning that the radio cutout is still original.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
![]() Join Date: Nov 2001
So, just to verify...
67, 68, 69, 70, 71 & 72 AC systems DO all interchange... One from a 72 will work on a 68, and 71 will work on a 69, etc... As long as both are AC cabs all is well...? I have a 67 factory air cab... I can look for stuff off ANY year AC truck 67-72..? Correct...?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
Here is a old post that may help in your quest.LOL
http://67-72chevytrucks.com/vboard/s...85#post2012385 |
Can you make your own holes in a non-a/c dash for the three ducts? I beleive the dash is spot-welded in right? Is the holes for the control panel the same size? I have been wondering about this for a long time. This forum is awesome!
Yes, but you need to make a template, the cut is oblong.The control holes are the same.If you dont have access to an AC dash PM me with an address and I'll send you the templates.
