Old 10-08-2008, 12:40 PM   #1
71 3/4 ton
71 3/4 ton's Avatar
Exhaust gaskets????
i have 3 exhaust leaks cause by blown out exhaust gaskets
i have replaced them 3 times and cant figure out why they keep blowing out
should i put performance gaskets on? and if so where can i get them?
what else could the problem be??
71 3/4 ton is offline   Reply With Quote
Old 10-08-2008, 12:50 PM   #2
lowriden58
lowriden58's Avatar
Re: Exhaust gaskets????
manifolds or headers?
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 10-08-2008, 01:20 PM   #3
cdowns
cdowns's Avatar
i've always liked the deadsoft copper gaskets weather headers or manifolds// dont over tighten the exhaust because with wexpansion while hot they can mush cut and generally help the gaskets fail
Old 10-08-2008, 01:25 PM   #4
thirdstreettito
Resident of Here
thirdstreettito's Avatar
COPPER! Lemons headers(Custom made to order headers)recommends copper. It is flat and NEVER leaks.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 10-08-2008, 04:07 PM   #5
El Jay
Gone to greener pastures
Copper.
I got tired of burning/blowing out exhaust gaskets. I finally went to copper & haven't had a problem since.
I developed an exhaust leak when a header bolt backed out.
I retightened the bolt, the leak went away and the gasket was fine.
That's my.02
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 10-08-2008, 04:15 PM   #6
leddzepp
Moderator
leddzepp's Avatar
I have heard from some people not to even use gaskets between the exhaust manifold and the head...just tighten down real well.
leddzepp is offline   Reply With Quote
Old 10-08-2008, 04:27 PM   #7
lowriden58
lowriden58's Avatar
thats why i asked him if he was running manifolds or headers
Old 10-08-2008, 04:41 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the question can't be answered till the OP answers lowriden's questions.
We also need to know if he is talking about gaskets on top, to the head, or on the bottom, to the pipe.
Old 01-14-2009, 02:49 PM   #9
spudly
spudly's Avatar
I've got a manifold leak right now and I'm planning on redoing the exhaust all the way back using the stock headers.
So, would a copper manifold gasket be the best choice? And what would be the best choice for a flange gasket at the pipe? Part numbers are appreciated if you have them
This would be on a stock '71 350.
spudly is offline   Reply With Quote
Old 01-14-2009, 02:55 PM   #10
70GMCer
70GMCer's Avatar
I didn't have any luck with the copper ones. I went and used the stock OEM manifold gaskets & never had a leak again. And that's using headers also.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-14-2009, 05:04 PM   #11
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I've always used the factory gaskets for manifolds with my headers. NEVER had a leak. Also, I use 3 inch doughnut gaskets where the collector bolts to the header,also never leaked.
--Josh
