10-08-2008, 03:53 PM | #1 |
What's wrong with my truck?
The truck has been parked for 1 month. Today I installed a new spark plug wires and a new edelbrock chrome air cleaner. The truck started very well in the morning, but after 4 min. in idle the engine stopped, I tried to start the engine again but it never turned on, looks like the carb is flooded or something then I checked the wires position and everything is ok... maybe the new filter is affecting the hot starting? after 2 hours the engine started again without problems but turned off few minutes later help me guys!
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) Last edited by andresco50; 10-08-2008 at 03:54 PM. |
10-08-2008, 03:57 PM | #2 |
Re: What's wrong with my truck?
Sounds like maybe your new breather is interfering with the choke mechanism
10-08-2008, 04:05 PM | #3 |
Georgia Boy
Or something electric is heating up and shutting the truck off.. does sound like a choke problem tho.. take the air cleaner off and see if it'll idle for a while then.
10-08-2008, 04:28 PM | #4 |
i had that happen before..it was the air cleaner hitting the choke keeping it closed....I just got a 1in spacer and fixed everything.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
10-08-2008, 04:33 PM | #5 |
Yea maybe the choke is the problem I'm going to install the old air filter again.. to see what happens
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
10-08-2008, 04:34 PM | #6 |
A carb spacer? you have the edelbrock part??
10-08-2008, 04:36 PM | #7 |
not a carb spacer, an air cleaner spacer...get em at any good parts store..most are 2in but you can find a 1in.. or whatever size you may need.. try running it without the air cleaner and see if it still does it
10-08-2008, 04:40 PM | #8 |
I have the same problem with or without the air cleaner...
10-08-2008, 06:32 PM | #9 |
I can't start the truck when is hot!!!
10-08-2008, 07:36 PM | #10 |
Robert Olson Transport
Is it possible that you damaged the choke linkage when you did this?
10-08-2008, 07:47 PM | #11 |
If the timing is too far advanced it can cause that problem.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
10-08-2008, 08:28 PM | #12 |
I didn't touch the choke.. the choke is ok, when I started the truck in the morning it works very good
10-08-2008, 08:30 PM | #13 |
Yes that could be the problem but the engine runs very well in idle
10-08-2008, 08:44 PM | #14 |
You say it sat for a month and it seems like the carb is flooding i,m wondering if the needle is stuck in the carb and it,s just filling up with gas and stalling then after it sits for awhile the gas has evaporated and it starts again.A sign that the needle is sticking is to shut it off when it,s warm and you will see what looks like smoke coming out of the carb for a bit
10-08-2008, 08:58 PM | #15 | |
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) Last edited by andresco50; 10-08-2008 at 09:04 PM. |
