Hood hinges w/22s?
Ive got a 69 short bed and im gonna run the porterbuilt front crossmember, with a 22 in wheel.. What do i need to do with the stock hood hinges??
Re: Hood hinges w/22s?
remove them and get different ones...there going to be in the way.
heres a link that might help click here
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean Last edited by FnLow69; 10-08-2008 at 11:41 PM. |
3DrDwn--the 'burb not the band
sad but true stock hinges are bye-bye if you're laying it out. totally worth it tho
![]() Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 ![]() duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
![]() Join Date: Feb 2008
so what hinges are you using?
right now I have the parts to do the suicide using buick parts but not sure I wanna go that route. If you look in the faqs Rockcrln did a awesome write up on the buick hinge and the was a post ( search mercedes hinge) on a couple of options to keep a trad. open hood style. You can also check out Mark Barbee's truck with the full actuated hood if you wanna go crazy
![]() Josh
drag it like you stole it
i know i have seen some pics of hinges coming out of the firewall or either the wiper cowl. maybe someone can point you in the right direction.
negative camber //LA\\ |
