10-09-2008, 08:32 AM | #1 |
Junior Member
Will this work
I have access to a 76 4wd chassis. Will my 71 body and bed fit this chassis?
71 C10 Step Daily Driver 72 K10 Suburban Work in Progress www.louisianaclassictruckclub.com |
10-09-2008, 11:39 AM | #2 |
Re: Will this work
with modification to the 76, yes, it should fit.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
10-09-2008, 10:15 PM | #3 |
Enjoying left field
Re: Will this work
I tried this before, there is a difference in wheelbase. I can't remember which way it goes though.
10-09-2008, 10:27 PM | #4 |
I'm a poor spectator
Re: Will this work
I think you'd be in for a lot of work, not just a simple bolt and go deal.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
10-09-2008, 10:32 PM | #5 |
its all about the +6 inches
Re: Will this work
assuming LWB, the 76 is a 131 inch wheel base verses the 127 on the 71.
You'll have to relocate the rear axle, since the frame isn't flat like the 71, you'll have to make a custom lift kit to lift the cab up to the bed possibly fab up all the cab/core support mounts It's doable, and has been done. Mudder has a square body frame under his red stepside. |
10-10-2008, 08:47 AM | #6 |
Junior Member
Re: Will this work
Thanks Guys, got in touch with Mudder, and he told me what I needed to do.
