Old 10-09-2008, 07:12 PM   #1
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
Dome light not working?
hey guys, im in the process of putting my 79 interior back together, and came to the point where the dome light isnt workin, or the cargo light. i used a test light and there is no power in the clips on the switch. but my other interior light works, by the floorboard. is there a fuse that has blown or what? any help?
thanks
jrsmith
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE!
1983 Scottsdale-on the back burner...SOLD!!!
1992 Silverado- extended cab, stock for now, but no promises SOLD!!!
2006 Chevy Cobalt-college car, staying stock
Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow.
jrsmith_2010 is offline   Reply With Quote
Old 10-09-2008, 08:29 PM   #2
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: Dome light not working?
Does it work when you turn the headlight switch?
Albatrossian is offline   Reply With Quote
Old 10-09-2008, 08:33 PM   #3
jrsmith_2010
I like turtles...
i just checked, and no it didnt
Old 10-09-2008, 08:38 PM   #4
Albatrossian
Georgia Boy
Check your bulbs.. if thats not it, theres a short somewhere
Old 10-09-2008, 08:38 PM   #5
jrsmith_2010
I like turtles...
all the bulbs are good, that the first thing i checked. where would the short be at ya think?
Old 10-09-2008, 08:41 PM   #6
ton*loc
ton*loc's Avatar
you have dome light and a cargo light >? weird
all i got is a light under the dash. or is that what your talking about
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada
MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm
MMA RECORD 24-5
ton*loc is offline   Reply With Quote
Old 10-09-2008, 08:45 PM   #7
jrsmith_2010
I like turtles...
no, my silverado has a dome light, underdash light and cargo light. the cargo light and dome light have the same switch
Old 10-09-2008, 11:05 PM   #8
keith61760
keith61760's Avatar
Check the connection behind the drivers side seat. The wire runs from the under the driver side dash behind the drivers seat, up the cab to the light. Also where it goes under the skin of the roof there are some rough metal spots that may chafe the wire. Out of 6 trucks I have found 2 of them with corroded connectors.
keith61760 is offline   Reply With Quote
Old 10-09-2008, 11:30 PM   #9
andresco50
andresco50's Avatar
Check the wire system, change the bulb and check all the fuses....
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 10-10-2008, 06:49 AM   #10
mhicks
mhicks's Avatar
My '73 dome light only works from the door switches. It would not work when I got it from my Dad. Ended up replacing both switches. The switches have to be grounded to the body (door jamb). Mine were not when I installed the new ones. I had to do a little scratching around the hole to get a good contact. I also have a light under the dash in the center. It is turned on by the headlight switch.
mhicks is offline   Reply With Quote
