10-09-2008, 07:25 PM | #1 |
Freeze plug
When a freeze plug goes out on a motor, what does this usually mean? Reason I'm asking is a used motor I'm planning on buying needs one replaced.
By the way, we DON'T have cold weather down here. What else could it be. Block expanded/warped?
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
10-09-2008, 07:33 PM | #2 |
Re: Freeze plug
you going to rebuild it? if so replace all of them.
10-09-2008, 07:55 PM | #3 |
Re: Freeze plug
I hope not! I'm not planning on it any time soon. But he did notify me about the freeze plug needing to be replaced and when I went to take a look at the engine, I noticed a lot of liquid (couldn't really make it out) on the crossmember lip. The engine is still in the other truck.
10-09-2008, 07:56 PM | #4 |
Re: Freeze plug
I'm just scared to buy an engine that is on it's last leg, and honestly my budget would be wrecked if I had to rebuild a 454.
10-09-2008, 08:23 PM | #5 |
Low & Fast!
Re: Freeze plug
A freeze plug can be replaced with out rebuilding the motor, you will have to get a freeze plug kit then tap it in. You should be good to go after that...
10-09-2008, 08:25 PM | #6 |
Georgia Boy
Re: Freeze plug
If they're not brass, they're usually steel.. they just rust to pieces. Not a problem.
10-09-2008, 08:36 PM | #7 |
Re: Freeze plug
I can sleep easier tonight. Thanks a lot guys.
10-09-2008, 11:51 PM | #8 |
Sb 400 club
Re: Freeze plug
yeah I have seen them drop out in the spring on a 500 big block caddy. they just rotted out (they where steel). I would look the block over very carefully. IT is more common then you think but would be a large concern to me.
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
10-10-2008, 12:29 AM | #9 |
Re: Freeze plug
That's what was concerning me, that the block actually cracked for whatever reason and the freeze plug gave out at the same time.
10-10-2008, 12:36 AM | #10 |
STOP! Hamma time!!!
Re: Freeze plug
When I bought my GMC with a 305, it had set up for 4 years. I had to tap out and replace a corroded freeze plug behind the starter. I drove it for 5,000 more miles with no issues. But when the block froze, it didn’t pop one plug.
Plan your work and work your plan!!!, or pitty da fool!! 87 GMC BaseTrim, 305 under the wrench/TH400/ 92 Chevy 1500, 350,TH700R4 sittin on dubs |
10-10-2008, 12:57 AM | #11 |
Re: Freeze plug
Man! That's exactly what I'm trying to avoid. It's a nice built 454 for drag racing, but with all the mods it had a 13.2 sec pass seemed kind of off. It'd be nice to have a fast truck, but I can't afford to buy another engine down the road, I need something that'll last me a while. Thinking of just buying a short block 350 and building from there with all new parts and peace of mind.
10-10-2008, 02:01 AM | #12 |
Sb 400 club
Re: Freeze plug
ahh a race motor....l hmm this seems off to me too. especially if it was recently built. The saver route is to build a 350 short block. But if it is a solid motor the 454 would defiantly be more fun. Do you have a friend that builds motors? might not hurt to have a very knowledgeable person look at it with you for a second opinion. If your seriously considering the motor might be a good idea to pull the pan as well and have a look. This is not always possible but it does not hurt to ask.
10-10-2008, 07:20 AM | #13 |
Georgia Boy
Re: Freeze plug
You could always do a compression check to check for cracks, too.
10-10-2008, 03:57 PM | #14 | |
Re: Freeze plug
Anyway, here is the pass of the motor in it's current home: He did two passes before the track officials stopped him because of the leaking freeze plug. Don't know if it went out due to the run though.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 Last edited by Low84; 10-10-2008 at 03:57 PM. |
10-10-2008, 03:58 PM | #15 |
Re: Freeze plug
That might just be the only other option. Thanks.
10-10-2008, 07:59 PM | #16 |
Re: Freeze plug
Wooden dowel and just a lesst han zero guide coat of blue loctite around the outside. Comp test on all cylinders and try to determine if it went from in or out side.
