10-09-2008, 08:26 PM | #1 |
High or lo hump
Hello All,
I want to buy carpet for the 69 GMC, but when I checked on it, they wanted to know if I have a high or low hump. How would I know? It is a 396 BB with 400 turbo trans automatic Thanks all in advance, Rick |
10-09-2008, 08:41 PM | #2 |
Re: High or lo hump
I believe that the high hump is for a manual trans with floor shift. My auto has a low one.
10-09-2008, 08:54 PM | #3 |
its all about the +6 inches
Re: High or lo hump
if it is an original big block/auto, then it is a high hump.
Pull back the carpet, and see if the hump is bolted in. If so, it's a high hump. If it is part of the stamped floor, it's a low hump. |
10-10-2008, 08:51 PM | #4 |
Re: High or lo hump
Where is the best place to get carpet?
I need some black for Hi Hump No fuel tank in cab. Evidentily ACC does not carry or make it. Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
10-11-2008, 02:58 AM | #5 |
Moderator
Re: High or lo hump
05-12-2009, 07:13 PM | #6 |
Re: High or lo hump
I tried to order carpet today for my 71 Burban and ACC asked me if I had a 350 or a 400 tranny, but it came to me with a 350CI and a 700R4 tranny, so how do I know? It is a 3/4 ton 8 lug. The glove box says "M-49 TURBO HYDRO-MATIC" So which one do I order? Please help as they want take it back if I order the wrong one. Thanks Rob
05-12-2009, 08:39 PM | #7 |
Re: High or lo hump
they are retarded. TH350 and TH400 wouldn't make a difference on the floor.
if it is an original big block/auto, then it is a high hump. If it is an original 4 speed, it's a high hump. If it is an original 4X4, it's a high hump. All others SHOULD be low hump. Some odd ball trucks have made it off the assembly line with wrong humps. Pull back the carpet, and see if the hump is bolted in. If so, it's a high hump. If it is part of the stamped floor, it's a low hump. |
05-12-2009, 08:39 PM | #8 |
Re: High or lo hump
And FYI... M49 could be TH350 or TH400.
05-12-2009, 09:13 PM | #9 |
The Black Pearl
Re: High or lo hump
I have a 396 with turbo 400 also and it is high hump
05-12-2009, 11:32 PM | #10 |
Re: High or lo hump
Thanks for the help. Rob
05-13-2009, 01:42 AM | #11 | |
resident oilfield trash
Re: High or lo hump
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
05-13-2009, 09:18 AM | #12 | |
Re: High or lo hump
As Andy said the best way to be certain is to pull the carpet back and you'll know for a fact which one you have regardless of what your truck had or has now for a powertrain.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
05-13-2009, 08:09 PM | #13 |
Re: High or lo hump
ACC isn't a very good carpet kit to buy either. I've had mine in for a little over a year... to include a few months of the suburban being parked in a dark garage... and the carpet is already faded a little.
05-13-2009, 08:42 PM | #14 |
Re: High or lo hump
High hump
... ... low hump
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-13-2009 at 08:46 PM. |
05-13-2009, 10:41 PM | #15 |
Re: High or lo hump
does any body make replacements high humps
05-13-2009, 10:52 PM | #16 |
Re: High or lo hump
not that i know of you can find them
