10-09-2008, 11:25 PM | #1 |
Strange Cousin From The West..
Starter Question.
Will the Starter off of a '72 (2wd) 292 w/a granny low 4-speed work on '72 350 (4wd) w/the same trans. I have the Starter off of the 6-cyl, it is a brand new Napa Reman, from what I can see it looks the same externally, I imagine it would come down to a matter of meshing with the Flywheel.
10-09-2008, 11:31 PM | #2 |
Re: Starter Question.
if you look it up at autozone, it says they require two different starters ...
1948 CJ-2A Jeep 3spd 1961 C2500 305 V6 4spd 1967 C-10 Long Fleetside 1968 C-10 Long Stepside 250 Saginaw 3spd 1978 Scottsdale K10 355 4spd 1983 Honda Shadow VT750 1990 Toyota 4Runner SR5 4x4 5spd 2008 Toyota Yaris 1978 Scottsdale K10 355 4spd the "Ruby Build" |
10-09-2008, 11:35 PM | #3 |
didn't think of looking there, but if you look closely, the Valuecraft (3635S) one is the Same for both. the 4x is a K20, if that makes a difference.
EDIT: Looks like the Duralast (DL3635S) is the same too... Last edited by Shaffer4; 10-09-2008 at 11:37 PM. |
10-10-2008, 08:40 AM | #4 |
Active Member
I't been many years ago, but I'm pretty sure I used the same starter when I coverted from 250 three speed to 350/350 on my 69 Chevy.
I've always figured they were interchangeable and didn't have any problems. Anyway here's a bump in case someone has a different opinion or has recently done this. |
10-10-2008, 09:40 AM | #5 |
Sisyphus was my mentor!
It should work. GM starters (of our era) are all the same frame. If it doesnt bolt up, it's an easy swap to change the starter nose from one starter to the other.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
10-10-2008, 10:42 AM | #6 |
As long as the tooth count on the flywheel is the same. Since the starter bolts to the bellhousing.
10-10-2008, 03:57 PM | #7 |
They should fit but sometimes they designate the heavy duty starter. The HD starter can be identified by the spacer between the terms. comeing out of the motor & the connection at the selinoid. The HD starter has 2 terms. comeing out of the motor & about 3/4 in space to the selinoid. The light duty has the term hooking right to the selinoid or only has one term.
10-10-2008, 05:24 PM | #8 |
Apparently it must be the Right one, because it is in and working, and Oh baby does it work.... no more rrrrr-rrr-rrrr-rrrr-Vroom, its rrt-vroom now
The one I put in is at least a half and inch longer throughout. |
