10-10-2008, 11:58 AM | #1 |
Tracking Device
I am restoring a 69Camaro and I found something that looks like some sort of a tracking device. Anyone have an idea what this can be?
It was hotwired to the cigarette lighter, and connected to ground, this were the only connections. The device had a 12V battery attached to it, and an antenna under the dashpad. The device was found hidden behind the kickpanel. |
10-10-2008, 12:04 PM | #2 |
Looks good at 20-ft .....
Re: Tracking Device
Sounds like a tracking beeper device or an audio eavesdropping bug transmitter. Most of those use a 9-volt battery though, from what I've heard.
Conspircay Theory, anyone ????? |
10-10-2008, 12:09 PM | #3 |
Re: Tracking Device
sorry someones gotta do it
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 http://i195.photobucket.com/albums/z...en58/001-2.jpg |
10-10-2008, 12:10 PM | #4 |
Re: Tracking Device
Maybe a lojack?
10-10-2008, 12:12 PM | #5 |
Re: Tracking Device
Photos? Inquiring minds want to know.
10-10-2008, 12:18 PM | #6 |
Re: Tracking Device
Here is a pic
67 c10 Short Step 350/th400 daily driver 69 Camaro work in progress |
10-10-2008, 12:31 PM | #7 |
Always on the hunt...
Re: Tracking Device
Part of a pager alarm system? ? ?
10-10-2008, 12:35 PM | #8 |
Re: Tracking Device
Transmitting device of some kind, because of the FCC paper tag with it.
Should be able to find out what that is by checking the FCC number with them. I'm betting on a Lojack type anti-theft tracking device, though I wouldn't really know one if I saw one. Somebody on here will know more than I do about those. |
10-10-2008, 12:58 PM | #9 |
3DrDwn--the 'burb not the band
Re: Tracking Device
It appears to be a paging unit that was popular on alarms in the 80's.
I'll bet that there was an alarm that someone already removed but left the page unit behind because they lost the dedicated pager. The box would have had a red hot wire, a black ground wire, and an orange "trigger" wire that would have sent the paging signal when it recieved a ground input from the alarm brain. The supplemental battery allowed the signal to be sent even if the main vehicle battery has been disconnected. based on my years spent as a MECP certified audio/security/cellular installler that's my best guess. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
10-10-2008, 01:04 PM | #10 |
It's a catastrophic success.
Re: Tracking Device
Was there a cover on the (curcuit board) box?Any numbers
The thing in the bottom of pic is a battery. |
10-10-2008, 01:16 PM | #11 |
Re: Tracking Device
No orange cable, only red 12V+ and black grounded. And a black coax antenna under the dashpad.
FCC ID: IDILJU-02
10-10-2008, 01:35 PM | #12 |
Re: Tracking Device
I think he means this one went to the alarm sys, (the trigger wire).If alarm has been removed then the wire wouldnt be hooked up.
10-10-2008, 01:54 PM | #13 |
Re: Tracking Device
Snakes got what I'm sayin
Josh
10-10-2008, 01:55 PM | #14 |
Active Member
Re: Tracking Device
Because it was attached to the cigarette lighter I think it may be an anti- smoking warning devise. It is installed to send a signal to your wife every time you use the lighter to light your cig. These units were sold by the anti-smoking people to rat out husbands who promised their wife they would stop smoking and then smoked in their cars. Not many people know about them because the program was kept a secret. As years passed and guys sold their cars the devices were discovered hidden in different places in the cars by the new owners. Those wives and anti-smoking people will go to any extent to advance their no smoking agendas. LOL
10-10-2008, 02:21 PM | #15 |
Between Trucks...
Re: Tracking Device
WMD, car bomb...
Beat it to fit, Paint it to match... Last edited by Sinister; 10-10-2008 at 02:21 PM. |
10-10-2008, 02:31 PM | #16 | |
Re: Tracking Device
10-10-2008, 02:47 PM | #17 |
Certified BFH Operator
Re: Tracking Device
And all this time, I just thought the Smoke-Out deodorizer wasn't working......damn
- 1969 swb C/10 fleetside -LSx swap and Resto in progress LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay... -1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle |
10-10-2008, 02:53 PM | #18 |
Active Member
Re: Tracking Device
Thank you Gator 2511, that's where I am writing from.
10-10-2008, 03:28 PM | #19 |
Re: Tracking Device
Sorry to mislead you RunninLo. One orange and one black cable to the battery, one black to ground and red one to 12V+. No triggerwire for alarm
10-10-2008, 08:38 PM | #20 |
Re: Tracking Device
no worries norwegian. It's been at least 15 years since I've seen a paging unit anyway so I was mostly grasping. FWIW I'm glad the went with the 2 way in the remote fob instead of the pagers. My #1 least favorite alarm feature was the REALLY old style that had a keyed lock cylinder that a lot of people mounted in the driver fender just behind the wheel opening. I still cringe when I think of all the mint sheetmetal that got a hole in it.
Josh
10-10-2008, 09:51 PM | #21 |
Re: Tracking Device
it is probably an alarm pager as suggested...
HOWEVER, I will suggest a different story: Step 1) cheating spouse Step 2) private detective Step 3) messy divorce ...ask me how I know. --steve
Help! My project parts hauler became a project! |
10-11-2008, 03:01 AM | #22 |
Re: Tracking Device
the FCC ID is for a LoJack tranmitter certified before 1995. since its that old its not gps. probably uses triangulation. there watching you...... lol good luck with that.
John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
