Old 10-10-2008, 09:44 PM   #1
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
A/C Question...Help Please
I am putting a compressor, drier, and the hose assembly on a 99 suburban. I am not going to be charging the system; a shop will do that for me.
My question is: Is there anything special I need to do? Does anyone have any helpful tips, tricks, pics? Do I need to put oil in it if the shop is going to charge it?
I was thinking about the job and wondering if I should do this. I know I can put all the stuff on. Just want to know if there is anything I should do. Any help is greatly appreciated. This is my parent’s truck and I am trying to save them money. I would hate to not do something and mess it up.
THIS BOARD IS AWSOME.
P.S. I know it's not the right year for this section but this section has a lot of people looking at it. And I know there are some real techs out there that could probably help.
LOW DOUGH is offline   Reply With Quote
Old 10-10-2008, 11:41 PM   #2
clay68c10
clay68c10's Avatar
Re: A/C Question...Help Please
Put it together and let the shop do the charge and oil. If they have a good a/c machine it can add oil when they're charging it. They can also tell you if you need to add any. If there was oil on the new compressor you're probably good to go...
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 10-11-2008, 12:09 AM   #3
WorkinLonghorn
WorkinLonghorn's Avatar
Don't over-tighten the fittings.Hopefully you have the torque specs,if not you should can look them up.I have them around here somewhere if you can't find them.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 10-11-2008, 11:22 PM   #4
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
Thanks yall. The hose assembly was wrong. It's my fault. The burb has rear air and we had the hose for front only. A week ago I was helping a friend tear down an '89 burb w/ rear air and noticed it had a "T" in the line by the drier that went under the cab and to the back. I should have known this one should/was the same. Didn’t see parent’s burb till today. Of course the parts store didn't carry the line I needed. Had to order it from NAPA. So not doing it this weekend or the next or the next. A buddy of mine is going to do it at his shop. Cool. Thanks again for the info and tips.
Old 10-12-2008, 08:25 AM   #5
ChevyTech
As clay68c10 said the new compressor could have come with oil in it. The shop may want to put the oil in it so they are sure there is oil in it, and the correct type of oil is used.
I got in the habit of draining the oil out of the new compressors to measure it because I found them to have an inconsistent amount of oil in them. This was in the compressors we were getting at the dealership.
It would be a good idea to talk to the shop you are going to have charge the system, about the oil, before you do the work.
Old 10-12-2008, 10:50 AM   #6
PT'S 70 CST
"GO DAWGS"
PT'S 70 CST's Avatar
The biggest concern to me would be what kind of compressor are you using. If you are going with a autozone,advance or one of those type auto parts stores remanufactured compressors, then you will be making a big mistake. I tried that when my A/C went south on my 94 and wound up replacing the compressor twice before I went to GM and bite the bullet and bought a new GM one. Those stores will give you a 12 month warn. but it will not cover the labor or having it recharged. I am telling you there is no way I will ever try and save $ like that agian. It wound up costing me way more then I thought after replacing advance's junk compressors twice.
PT
70 CST SWB
70 NOVA
93 Indy 500 Pace Truck (SOLD)
94 SILVERADO SWB 5/7 drop
2000 Silverado swb
2005 Nissan Altima 3.5 (Surprisingly very fast)
2004 GMC Yukon XL Denali
BATESBURG, SC. 29006
29006
Some of my restorations
http://www.snapfish.com/snapfish/thu...NAME=snapfish/
Restored Tach tins 8 cyl - 6 cyl
http://67-72chevytrucks.com/vboard/s...d.php?t=518185
Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM
God Bless Our Troops
PT'S 70 CST is offline   Reply With Quote
Old 10-12-2008, 09:27 PM   #7
bwood
bwood's Avatar
None of the compressors I have installed in the past few years came with oil in them. Both reman and Delco/Delphi. They all have paperwork saying how much to add. On the last few Delphi's they actually had a sticker that said how much.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 10-15-2008, 04:30 PM   #8
catch-22
I rebuilt the A/C system in my 96 Sierra - did everything from the Evaporator/dryer, Condensor, hoses and compressor. I put in an Autozone compressor which was not filled with oil. I found online somewhere how much oil to put in. I bought a recharge kit which came with the refrigerant and oil, but I also bought extra oil. If you're putting everything in yourself, that's the hard part! The recharge kits are easy - you can't connect it to the wrong ports, the connectors only go to the right one. I don't know how much the shop is going to get for the recharge and oil - but its got to be cheaper to buy the kit and do it yourself. Mine came with a DVD and it was easy. I was very happy when I got cold air out the vents
catch-22 is offline   Reply With Quote
Old 10-15-2008, 04:37 PM   #9
catch-22
Oh yeah - when I tried to take off the connector from the Dryer to the line that goes into the firewall - the entire pipe and connector started to twist. The Nut and dryer is made of aluminum and was fused to the steel(?) hose coming out of the firewall. I ended up taking a sawzall to the nipple on the Dryer, heated it up with a torch and got that fitting off. All the aluminum fittings seemed to fuse their threads. A little heat from a torch made them all come off nicely. I cleaned up all the threads with a wire brush thingy on a drill before I put in all the new stuff
