Old 10-11-2008, 12:44 AM   #1
crasten123
crasten123's Avatar
How are you running your exhaust? PICS?
I'm just about done with my rebuild and purchased some headers for ECE. Now I'm tyring to get an idea on how to route the exhaust. My truck is lowered 4.5/6. I dont want to have any clearance problems with the pipes or mufflers. Does anyone have pics of their exhaust? I have a 72 SWB.
I'd really appreciate any help.
[B]72 Cheyenne SWB
crasten123 is offline   Reply With Quote
Old 10-11-2008, 05:10 AM   #2
67dragtruck
67dragtruck's Avatar
Re: How are you running your exhaust? PICS?
I"m running a mid length header instead of a full length so it won't hang low. Then I'm cutting 4" holes in the trailing arm crossmember and welding 2" pieces of 4" diameter 1/4" wall pipe into the holes. Going to Pass 3" dual exhaust through the holes. It has a 3.5" inside diameter so it has 1/4 clearance all around. Going to run 2 chamber flowmasters with turn downs after the rearend. I'll be modifying the crossmember this week and will take some pics. I did it once before with flat metal to support the crossmember where I cut the holes, but the pipe will be much stronger.
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc.
My new build thread:
http://67-72chevytrucks.com/vboard/s...17#post2861817
Best pass with the old dragtruck:
5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003
Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup
5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004
67dragtruck is offline   Reply With Quote
Old 10-11-2008, 09:19 AM   #3
ECE now makes a coil crossmember with holes for exhaust,if you just want bolt-in.
Old 10-11-2008, 10:12 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
There's a board member on here that has actually ran their exhaust on their 4/6 lowered truck back to the rear bumper, which is what I'm going to try and accomplish. I'm planning on running either huggers or 3/4 length headers to keep everything about the frame rails. I'm also going either modify the original crossmember as 67dragtruck stated, or I might opt for the ECE member like Special-K mentioned.
Good luck with your build!
I found a pic of your truck, was the c-notch necessary? Or did it help with the travel of the rear suspension?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-11-2008, 10:58 AM   #5
71BB_LWB
Thread Killer!
71BB_LWB's Avatar
I'm going to the rear bumper and I'm running 4/6 drop, I built my own exhaust from mandrel bends.
I also did it with the bed and cab off the frame.
Check my build thread for some pictures.
71 Cheyenne SWB LS1 and auto.
http://67-72chevytrucks.com/vboard/s...d.php?t=256470
_____________________________________
If it's worth doing, it's worth doing twice...
Don't Mistake Honesty for Negativity...
71BB_LWB is offline   Reply With Quote
Old 10-11-2008, 11:10 AM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Great build!
-Nate
Old 10-11-2008, 12:04 PM   #7
70jnktrk
70jnktrk's Avatar
Here is how we did it on my 70 lwb..mufflers are outside the frame rails just ahead of the rears...4/5 1/2 ece drop..hooker full length headers..no problems
70jnktrk is offline   Reply With Quote
Old 10-11-2008, 01:19 PM   #8
whatnow123
whatnow123's Avatar
I can't post photos anymore (it tells me they are to big) but I have some picks in my build thread of my exhaust. Link is below.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners.
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=219094
whatnow123 is offline   Reply With Quote
Old 10-11-2008, 09:51 PM   #9
crasten123
crasten123's Avatar
THese are some great ideas. I'll do more research and send pics of the outcome. Not sure yet as to what mufflers to use.
TO 72blckbuty: I "c" notched the frame for "piece of mind". I had another 72 that I dropped 4/6 and didnt notch it...it would hit the rubber bumpers after each little bump. With the extra 1-2 inch travel it does make a difference. Just have to watch out for the 3rd member hitting the bottom of the bed. Here's pic of the 72 without the notch...with that much space it still hit the rubber stoppers periodically.
[B]72 Cheyenne SWB
Old 10-12-2008, 06:46 PM   #10
Yukon Jack
Post Whore
Yukon Jack's Avatar
Great looking truck - stance is great.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 10-12-2008, 08:22 PM   #11
70c10
67-72 Addict!
70c10's Avatar
Nice stance and wheels! What size are the tubes on the ECE headers?.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-13-2008, 12:14 AM   #12
crasten123
crasten123's Avatar
I bought them through ECE, but they are manufactured by Sanderson....1&1/2 inch tubes. Here's a link to Sanderson.
http://www.sandersonheaders.com/prod...roducts_id=199
[B]72 Cheyenne SWB
Old 10-14-2008, 07:29 PM   #13
67dragtruck
Here's how I modified my crossmember. Just did it this evening. I know I could have used a shorter piece of tubing, but I thought it looked cool like this. It definitely made it stronger than the factory way with the deep v's in it. The problem I had with the CPP one is that they say the holes are 3x5 and I want to run dual 3" exhaust without the expensive oval tubing. This way gives me a 3.5" hole. It's close, but should work fine.
Tom
Old 10-14-2008, 07:58 PM   #14
tommypic
tommypic's Avatar
I like the idea of cutting stock cross member . Beings I stole a Plasma Cutter , well might as well had for $300 . The only thing is I have mine already powder coated . I guess I could just paint it , being I am having to spray some black anyway .
My ZipCode = 29673
2008 Silverado Z71 LTZ Wrecked New Ride SOLD
71-72 Custom A/C Parts Truck < selling parts
67 Chevy ShortStep SOLD
67 GMC SWB Step <-- For Sell
67 Chevy SWB Step <-- working on
2000 Road King <-- SOLD
97 F150 my ride for now
2006 Escape wifes ride
HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php
Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2
tommypic is offline   Reply With Quote
Old 10-14-2008, 09:20 PM   #15
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
2.5" into 40 series flowmasters. Can't see the exhaust from the side.
westbrookw is offline   Reply With Quote
Old 10-14-2008, 09:36 PM   #16
GKsport67
GKsport67's Avatar
This is how i wanna set mine up!
GKsport67 is offline   Reply With Quote
Old 10-15-2008, 06:34 PM   #17
big_al_71
big_al_71's Avatar
I just got my exhaust done and here are the picts of what it came out like.
2 1/2 inch pipes with dynomax (changed my mind about the flowmasters)...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 10-16-2008, 08:08 AM   #18
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Looks great big Al!
-Nate
