Old 11-21-2002, 10:18 PM   #1
buggieo
frame identification??
Is there a way to figure out what year my frame is?? My 72 cab vin is for a 2 wheel drive and frame is 4 wheel and need to know what year it is so I know what to order for new chassis parts steerin etc.. any help is appreciated
thanks
buggieo is offline   Reply With Quote
Old 11-22-2002, 08:44 AM   #2
JimKshortstep4x4
Smile
If it is not bare and the brake setup is still intact, then if it has discs it is a 71 or 72 and parts wise it would not matter. If it is not a frame from our series trucks than I guess I don't know other than having someone look at it.
Jim
Old 11-22-2002, 10:32 AM   #3
buggieo
Smile
thanks Jim, it has drums all the way arround so must be a pre 1971
Old 11-22-2002, 12:08 PM   #4
JimKshortstep4x4
Smile
There is a number stamped into the frame but I believe that it is only part of the vin number without a date code. You would need the vin plate off of the cab to determine the date. I don't believe that you will run into a problem with parts as the frames were pretty much alike. The differences should be small for the 67-70.
Jim
Old 11-22-2002, 12:23 PM   #5
Rod
The number on the top frame rail is an indication of the year... the first number is the year.... could be a Z also which would mean 1970... if its all drums it's 67-70.... the 67-69 would have closed knuckles. If there's no numbers its probably a 67 frame.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
