Pick'n up the pieces!
Front stablizer bar interchange
I looking for a front stablizer bar. I have looked at the new ones, but surely there is some other years that will fit my 71 frame. Has anyone put a later model one on and if so what year did it come from. Btw I have ece's 2.5 drop spindles and 1 drop springs. Will this affect what stablizer bar I can use. Any info appreciated.
Danny |
i've got pretty much the same suspension as you. I've got a swaybar and brackets off a 72 3/4 ton truck. Everything went to gether fine. ECE offers shorter frame brackets if your concerned about your bar being too close to the ground. But I think anything off a 87-older truck will work.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Anything from 67-87 will work and anything from 1/2 ton to 1 ton.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
thanks, I'll hit the bone yard tomorrow!
its all about the +6 inches
3/4 to one ton is more likely to have a big 'ole fat one under there too.
My other Love
I guess I am lucky to have a factory sway bar
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
I went and robbed one from the local yard and it only cost me $20. I got the bar and all the brackets and bushing, btu I will be replacing the stock bushing with polyurathane ones
