68 bed vs 69 up bed
my 68 k10 came with a bad from a 69 -72 truck on it, and it was badly aligned about 1/4 inch between the bed and cab on the passenger side and about 2 inches on the drivers side
the bed has a steel floor, where originaly the truck had a wood bed i completely removed all the bed bolts in an attempt to align the bed, the bed is straight and square, and the cab and front clip are on and all aligned so my question is do 69-72 beds have a different mounting set up, or could it just simply be that the truck orignaly had a wood bed thanks nate
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
![]() Join Date: Jul 2001
Re: 68 bed vs 69 up bed
Years back I bought a 72 4x4 with the same exact problem. There was a very small gap on one side an a wide one on the other. Come to find out the frame was bent,it had a diamond type bend. I now always look at that when I look at a truck.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
where would i look for clues of a bend like that
nate
I don't think there is any difference in bed mounting over the years....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
thats what i am worried about the beds mounting the same
i guess i will pull the bed off and front clip is comming off in a couple of weeks so i can put my engine it, i will find out if the frame is straight by how the truck drives and what i can see with the front clip and bed off
![]() Join Date: Aug 2004
If you look at the top and bottom of the frame c-channel, it should have pretty smooth bends all along the frame rail. If you see any places where its pushed up or down, like a crimp or point, you've got some damage. Most of the factory bends are symmetrical from side to side, so that's also something to look out for.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
its all about the +6 inches
I would inspect the rear cab mounts
![]() Join Date: Nov 2004
My guess is that your cab mounts are shot.
Edit: too slow again...
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-11-2008 at 11:30 PM. |
