Old 10-12-2008, 09:12 AM   #1
jorgensensc
jorgensensc's Avatar
Roof Rack Question.
Does anyone have a GM accessory part number for the Suburban Roof Rack? I am trying to figure out some details, but am having some difficulty. I know at some point they had the one that kind of leaned forward in the front, then they changed to the ones that kind of leaned backwards in the front. I am really more interested in the one that kind of leaned forward. I don't understand what the difference in the number of feet is. I have seen some that have 2 feet per side, and others that have 3 feet per side. I also would like to know the dimensions of the suburban roof rack if possible. I know the blazer one is shorter, but I don't know how much shorter. If anyone could help me out I would really appreciate it. Pics are always nice if available, but I would really just be happy with an explanation at this point.
Thanks!
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-12-2008, 02:18 PM   #2
john
member #16
john's Avatar
Re: Roof Rack Question.
frizzle fry has one on his truck.
http://67-72chevytrucks.com/vboard/member.php?u=18620
john is offline   Reply With Quote
Old 10-12-2008, 08:03 PM   #3
jorgensensc
THanks John.
Anyone else got any info?
Old 10-13-2008, 11:33 AM   #4
Hart_Rod
Hart_Rod's Avatar
"Most" of the suburban ones have 3 feet per side. The only difference in the leaning forward and the leaning rearward are the 2 front feet and you can swap them out. Overall length is approximately 64". Here's pictures of both:
EDIT. Looks like the middle foot doesn't lean either, but if you found 2 front feet I'm not sure how much you would notice it.
Hart_Rod is offline   Reply With Quote
