too many toys
Not finding info on what i need for parts. I want to convert my 1970 gmc camper special 4x4 3/4 front dana 44 open knuckle .from drum to disc setup. Dont want to change whole axle.DIY4X4 doesen't list for this. Any help would be nice. Original drums are finaly garbage. thanks in advance.
![]() ![]() 1971 gmc 3/4 4x4 383 stroked 1968 1/2 2nd owner 4bbl 6cyl 1969 gmc 3/4 4 sale 350 4bbl 4spd 1969 chev 1/2 lowered 5 spd 454 4bbl 1947 chev coupe 2002 harley flhtcui 6 -67-72 my parts |
Re: dana 44 drum to disc conversion
Even if there is a kit to do this and retain the closed knuckle housing.....why would you want to? A conversion kit would cost more than just using an entire later-model axle...plus you would be stuck with those "special" parts for replacements later. Besides, an open knuckle axle will turn in a tighter radius anyway.
#3 | |
too many toys
I could be wrong, but I think all you need are the backing plates, spindles, rotor's, and hubs off of a disc brake dana 44 or 10bolt
Oops, bad reading, or lack of reading I guess? Sorry.
It is as simple of a swap as changing everyting from the ball-joints...out. Everything, including the outer half of the axle shaft. Realistically, you need a donor axle to swipe all of these parts from. It is still a lot of work, when a total housing switch is far easier. You just have to match the ratios up. |
#6 | |
![]() Join Date: Mar 2003
He will need the knuckles also. The disc brake backing plate bolt pattern is indexed different than the drum backing plates. That axle also has the small u-joints. |
It's the spidle,hub,backing plate that is needed. Not sure on the axle though but i'm pretty sure the knuckles are the same
Just find a matching ratio axle on Ebay or Junkyard ($200 max?) and bolt it right in... Or swap the parts... Much less hassle removing four U-bolts the the rest of the swap will take.. but... I have seen it done, let me find the link.. here you go http://www.wsu.edu:8080/~i6735189/di...conversion.htm
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 10-13-2008 at 07:56 PM. |
