Power Brakes are locked
I have just recently adjusted my brakes by the brake pedal and drove it once or twice and then today, the pedal wouldn't move. I was like the brake were applied the entire time. I doconnected the pedal from the MC and tried to move the push bar into the booster and nothing. just locked up.
It was a new booster and new MC with very low miles on them like mayber 50. Any ideas?
1969 GMC 3/4 Ton 4x4 2" Lift, A/C, PS, PB 383 Stroker, 700R4, 205, 4.10 GM Medium Bronze (Copper Poly) no new nick name yet. She is to pretty to be the Beater. http://67-72chevytrucks.com/vboard/s...d.php?t=241855 |
Re: Power Brakes are locked
You need a little free play in the pedal before it starts pushing the power brake unit. Also the shaft between the master cyl. & booster could be too long.
Sounds like you have the pedal adjusted to tight, and the master cyl. won't release the built-up pressure. As stated above, need about 3/8-1/2" freeplay at top of pedal. Just my $.02.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
The Older Generation
If you crack a brake bleeder screw it should release the pressure... LockDoc
