Old 10-12-2008, 05:28 PM   #1
68350
68350's Avatar
Bogging?
K, just bought a 79 chevy 4x4 with a 402. He said the fuel filter(glass one) likes to plug off every once in a while. Well I found that out quickly. Runs excellently until it plugs off or whatever is happening. I would pull over, take the filter off and clean it up quick and it would run for another 10 minutes. Anyway, what would cause it too plug off so fast? About every 10-15 minutes it happened. there's no air cleaner, which is another reason why I parked it at a buddys house, but that shouldn't have caused the bogging. It has an edelbrock carb(manual choke) and intake with two spacers. Oh yeah, has a hypertech street/strip hei in it. It only did it going up a hill. Pull over and put in park and it revved fine, so only under a load did it do it. thanks for any help.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 10-12-2008, 05:42 PM   #2
70GMCer
70GMCer's Avatar
Re: Bogging?
1st, get rid of that glass filter & put a different kind other than glass. Glass is dangerous !! Sounds like you have a lot of trash in the gas tank. That would cause the bogging & causing the filter to clog up.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-12-2008, 05:56 PM   #3
68350
68350's Avatar
Re: Bogging?
That's what i figured. But, why wouldn't it bog when put in park?
Old 10-12-2008, 06:07 PM   #4
El Jay
Gone to greener pastures
Re: Bogging?
There's no "load" on the engine.
It's just sitting there revving, not trying to move 1 1/2 + tons.
And listen to 70GMCer.
You'll be more than a little p.o.'ed if you break that filter and burn your truck to the ground.
And forget about plastic filters, too.
Steel is your friend.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 10-12-2008, 07:41 PM   #5
matthufham
Re: Bogging?
with my glass filter it wasn't that it broke, it was that the cheap end caps came loose and it wouldnt tighten up because the threads got messed up. it leaked for 2 miles all over the top of my engine, didn't start a fire but the overwhelming smell of gasoline, a melted fuse holder, and a couple discolored painted parts is all that happened. i got a metal fram one for a dollar more.
to answer your question, i'd say the rubber fuel lines may be coming apart on the inside and flowing upstream to the filter clogging it, or trash in the tank.
matthufham is offline   Reply With Quote
