Steering Blues
So I just got my beast drivable, and had it aligned at Les Schwab. They did a good job, but man the steering is shaky. I have power steering that may or may not be original to the truck. What do I do to make it steady and handle better? At any speed over 55 it gets pretty hairy, like I need two hands on the wheel hairy. What can I do?
Re: Steering Blues
Try balancing the tires.
Re: Steering Blues
How bout the idler and pitman arms? I think they need replacing. Would this cause bad road manners?
Re: Steering Blues
Two things come to mind tires with flat spots and re balancing them....Check the lugnuts make sure they are all tied..ask me how I know.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Re: Steering Blues
Well my tires were just balanced and installed at Schwabs, so I know that is good. What else should I check?
Re: Steering Blues
do you have a sway bar?
Re: Steering Blues
No sway bar. I would like to get one though. Would it make a difference? Could I get away with just a front one or do I need rear too
Black 72 Chevy
Re: Steering Blues
Check your shock absorbers.
72 Chevy, SWB, 350engine, TH400 |
#9 | |
Out of the carpool lane.
Re: Steering Blues
However, I might put a 3spd in your bed so that it lightens the load on the front wheels enough to stop the shaking. ![]() Seriously though, if ya can't figure it out I can take a look at it for you.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
Re: Steering Blues
#11 | |
Re: Steering Blues
Re: Steering Blues
I found a "steering stabilizer" kit from LMC truck. Does anyone have experience with this or know if it helps?
#13 | |
Re: Steering Blues
Yes, very much. Your pitman and idler arms are the only links between your steering assembly and chassis. Jack up your front end and rest it on stands. Grab the sides of each of your front tires at try and twist them back and forth in the same directions that they turn when you turn the wheel. Your checking for slack. It's best to have a second person under the truck to look at the steering/suspension components while you wiggle the wheels. If there's side to side slack it's either your pitman or/and idler arms, sometimes your tie rods. Next grab the top and bottom of each wheel and wiggle checking for slack. Any slack will be a bad ball joint/s. Idealy everything should be rock solid, not even a slight tick.
1970 Short/Fleet C-10 (Project) -Slammed and Tubbed 1955 Cameo -Straight six, Turbo Hydro option 1955 BelAir 2 door post -All original down to the oil bath air cleaner 1964 Corvette -All power A/C 327 4 spd. tanker ![]() |
#14 |
K5drive
Re: Steering Blues
Bad wheel bearings can make your steeing wheel shake real good.Maybe a little to simple for your symtoms but never the less its still worth the look.
#15 |
Re: Steering Blues
OK sweet. Well I just replaced a lot of the front sups. (drop spindles, springs, shocks, ball joints, tie rods, wheel bearings) but I didnt do the idler or pitman. I will do those and then re-align and hope it gets better.
#16 |
Re: Steering Blues
Do I need to replace both the idler arm and the bracket or just the arm itself
#17 |
Re: Steering Blues
i believe just the arm
