![]() Join Date: Feb 2005
WTB 72 GMC 4x4 rear stock springs
Since the stupid PO put 56" 1 ton rear springs on my 72 GMC 3/4 ton 4x4 I need a pair of rear springs. I would like to keep the truck stock height. The springs I need are 52" long 2.5" wide and should have 6 leafs. You guys with lifted trucks probably have some of these laying around! I need 'em! I also need shifter linkage from the column to the trans complete in case you run across this while looking for the springs. Thanks in advance.
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 |
Re: WTB 72 GMC 4x4 rear stock springs
If anyone has a source for these springs please let me know. I am learning that used originals are hard to come by!
I have a set of used 69 4x4 rear springs. I live in Texas.......zip is 75904
I have what your looking for...... shipping from from Texas may be high. My zip is 75904. Let me know.
sorry for the double post, I am new to this forum stuff. Lol
Let me know the weight on these things and rough dimensions on the package/packages. My zip is 83854 if you want to figure shipping. Let me know. You're right shipping could be pricey!!! Thanks for the reply.
Ups ground.... $115.00 +/- for shipping. Each spring weighs around 60 lbs. I noticed that the PO made some cheap version of a lift block with another leaf incorporated into the block.......It has 7 leafs instead of six. But the block could be easily removed..... $150.00 to your door.
68maniac,I found some springs locally today. Thank you for your time,I really appreciate the effort!
