Old 10-12-2008, 08:09 PM   #1
jorgensensc
jorgensensc's Avatar
8 lug drop spindles?
Do they make them? I just ordered new 8 lug wheels and hope I didn't screw this all up. I plan on bagging the c-20 Suburban and started thinking that I may need to use lowered spindles so they won't look crooked. Not slamming it or anything, just a simple 4/6 drop I think. So does anyone make them for the 3/4 ton?
Shawn
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-12-2008, 08:15 PM   #2
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: 8 lug drop spindles?
Got to use the newer 73 and up model. GMC Pauls has them, I imagine other board vendors would as well.
low'n slow is offline   Reply With Quote
Old 10-12-2008, 08:21 PM   #3
jorgensensc
They bolt right up to the existing ball joints right? The ball joints all appear to use the same part number. Can I use my existing rotors, bearing etc?
