Old 10-12-2008, 08:18 PM   #1
56hotrodred
removing brazing
I finally got around to getting the doors on - test fit to set up modified front rad support height & location - and see that one of the po's brazed the lower hinge to the door. Means I have limited adjustment on the drivers door and I can't get it to even close right now. I have the passenger door real close and feel pretty good about it. I am also getting the hood sanded to get it on to help me align the whole front end.
This is a 56 body on an 80 SWB frame so modifications and lots of test fitting are going to be needed.
My question is how do I remove the brazing? Heat or grind? Some of it is going to be pretty hard to get to with any type of grinder and I do not have a torch.
Also after soda blasting the cab there is brazing in several places. It all seems solid and looks like it is from the factory as I am told they did. Do I want to remove it? I was going to do a combination of weld and filler to smooth overlapping seams out in the cab. Not too sure how the brazing will react if I get close to it with the Mig.
Thanks in advance.
56hotrodred.
56hotrodred is offline   Reply With Quote
Old 10-13-2008, 12:15 PM   #2
mylow53
mylow53's Avatar
Re: removing brazing
you may have to cut out the pocket and replace it with sheet-metal from a doaner door. regardless your in for a fight! those doors are tough to get right
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 10-13-2008, 09:05 PM   #3
56hotrodred
That scares the crap out of me. There are several other fixes on this door that if I have start replacing the lower hinge pocket it may not be worth it. In looking a little closer at the upper hinge pocket I see stress fractures as well!!!
The passenger side door is in way better shape but that is usually the way it goes.
Anybody got a real good drivers door for a 56 1/2 ton in or near southern Alberta? I really do not want to go new.
56hotrodred
